Question about Dell W2600 26 in. LCD Television
DELL W2600 Power Fault
I have a Dell W2600 with the notorious power fault,only the relay in PSU clicks upon power up and no Leds light up,14v and 22v inverter lines missing,5v and 9v present.I have reflowed BGA I231 on main board and 2 other BGA's on main board and still the same fault occurs.I think it as been proven that the PSU is not at fault on the dell technicians forum.
  • rambo1cat Jun 27, 2008
    my problem is ,that I can watch my tv for 5 minutes and then all I see are vertical lines .I need to turn it off for a long period of time to get to anything for another 5 minutes .Some times I don't even see anything but the audio works. I tried evrything in the manual litterally. and it doesn't work
  • Anonymous Mar 23, 2014
    Keeps powering off. Have replaced all the caps on PSU board. Cannot access engineer mode to reset lamp fault if one exists.
    Problem Solver:
  • 10 Answers
Get yours replaced for free
http://www.dellcommunity.com/supportforums/board/message?board.id=si_hmtheatre&thread.id=2509
Posted on Jul 02, 2008
My Dell W2600 well not turn on have to unplug you can hear it click then plug back in and some time it will turn on
This sounds like Electrolytic Capacitors that are needing replacing, Common fault with LCD, If you know how to use electronic tools you can open the TV and you will see the tops of the capacitors are bulged and they need replacing.
Oct 25, 2010 | Dell W2600 26 in. LCD Television
Dell W2600 TV. Picture goes black after being on for 10 min.
http://www.shopjimmy.com/catalogsearch/result/?q=W2600
Back lights invereter or power supply. look for 24vdc on the power supply which is needed for the inveeter board.
look for bad caps in the power supply.
Nov 24, 2009 | Dell W2600 26 in. LCD Television
System will power on for about 3 seconds and then shut down and the blue indicator light on front is flashing
your poweredge has detected a hardware fault. If it is under warranty contact Dell. If it is out of warranty, you might carefully open the unit, and locate the fault diagnostic leds. They should be lit indicating the code for the fault condition/part.
Oct 13, 2009 | Dell PowerEdge 1650 Server
W2600 click but no picture, no warranty
if power light is lit, the main board needs replaced. It needs to have firmware M016, and REV A07. Thats the latest fimware out there available.
Sep 23, 2008 | Dell W2600 26 in. LCD Television
Power supply information
The fault is most likely in the power supply, or one of the other boards in the set has a fault condition that is causing the power supply to shut down. The only way to service the set is by doing board swaps to determine the defective board(s).
If you call DELL, they will tell you where to send the set for service.
Jerry G.
Apr 10, 2008 | Dell W2600 26 in. LCD Television
No power
get yours replaced for free
Apr 09, 2008 | Dell W2600 26 in. LCD Television
Dell w2600
There is no fix for the W2600. It has a power supply problem.
For sometime Dell was replacing the tv's with new ones, but don't think they are anymore. If you go to the Dell Forum and type in your tv you will see the amount of people that have had the same problem. Unbelieveable. As a matter of fact, Dell is not even making TV's anymore. Guess they gave up. They cannot be fix, cannot get the parts for it.
Mar 20, 2008 | Dell W2600 26 in. LCD Television
Dell W2600 TV
I have had the Dell W2600 for about 4 years. My remote for the Dell stopped working after 16 months. Since I was using cable I used the cable box remote. However, about 6 months ago a dark shadow appeared on some parts of the screen but the tv was still viewable. Shortly after, my power light would suddenly go out and then come back on after a minute or so. The problem got progressively worse until tonight it was off for most of the show I was watching and would come back on briefly. I popped the rear cover off and removed the metal shield and found most of the wires on one of the wire harness coming from the power supply board burned so badly the insulation was gone and the plastic connector assembly on the board melted. Because of the nature of modular board construction the power supply board and wire harness would need to be replaced and that doesn't necessarily mean the cause was fixed! To me this is a safety hazard. The TV is definitely out of warranty but I wouldn't expect this type of hazard problem. FYI, the parts I can read are made in China....what's new!
Aug 18, 2007 | Dell W2600 26 in. LCD Television
Dell W2600 Power Issue
>you can try this: Replace capacitor (10uF/50V) on small board >mounted to power supply next to mother board power connector.
didn't work for me. any other suggestions?
Jan 17, 2007 | Dell W2600 26 in. LCD Television
Dell W2600 26 in. LCD Television Logo
317 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
