Question about Keurig Special Edition B60 Coffee Maker
Keurig coffee maker had a foul, old, moldy, musty smell coming from inside the housing... where the water gets heated, not in the water reservoir. What is it? Will it make you sick if you drink coffee that has "run thru" whatever is causing the odor? How do you get rid of the source and the odor? How do you keep it from coming back?
  • 4 more comments
  • micolenill Oct 08, 2008
    When the coffee is brewing, you can smell the odor coming from the coffee dispenser and in the cup. The cup has a foul odor and there is a foul taste. It tastes and smells musty or like coffee that has been sitting at the bottom of the pot for weeks. We have tried cleaning with vinegar, which solved the problem for three days. The issue has returned after three days.
  • rolsol Nov 17, 2008
    I have only used my Kering B60 for one week now, but the flavor tastes like moldy plastic. I have tried running just hot water through, at least 2 resevoirs, still the bad taste remains. Please help.
  • Anonymous Dec 01, 2008
    I have had the keurig coffee maker just for a day, but am experiencing the smell of plastic or rubber in the water, coffee, and hot chocolate I have made. I have run about 10 cups of water to try to flush it out but no improvement so just checking to see if others are experiencing the same. I am pretty sure this is what has caused my lip to swell and some other allergic reactions I am experiencing now. It's too bad but i think I'll have to return it if some of you others are still experiencing it after a week or more of use. Any solutions yet? Not worth compromising health.
  • Anonymous Jan 03, 2009
    The water in the reservior smells and tastes like rubber and also has white and black particles when i brew just plain water. I would think that this is not a healthy sign and will return my Keurig for a refund because of this.
  • Anonymous Mar 03, 2009
    I have the exact same problem. I'm not sure if I should return it.
  • rckeystone Apr 20, 2009
    I have the same issue with my B60. I have a B40 at work and have never experienced this issue. I've sent an email to Keurig support and will await a response from them.
5 Suggested Answers
cmccune04
  • 213 Answers
SOURCE: The Water Reservoir is leaking on my keurig coffee maker.
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Posted on Apr 18, 2010
tgmusicgirl
  • 91 Answers
SOURCE: foul-smelling coffee
you may need to run white vinegar thru the unit... and dont be in a rush to get the vinegar out of it... let the vinegar work...
If you suspect bacteria, then mild bleach water... and dont be bashful about the quantity... allways filter the water and consider using bleachwater to clean the needles that puncture the kcups....
Posted on May 06, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have a Keurig B66, the reservoir water gets
Sorry to read about your issue.
Try this first....
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
heatman101
  • 43501 Answers
SOURCE: Keurig coffee maker sucks in
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
l;]p]0
Posted on Mar 01, 2011
heatman101
  • 43501 Answers
SOURCE: my keurig only dispenses half
heatman101
Keurig water/reservoir lid odor
Pull and Clean often. Ports are clogging up with debris.
Aug 31, 2012 | Keurig Platinum B70 Coffee Maker
Recalls on keurig
Empty the reservoir of any water. Fill it back up with white vinegar. Get a paper clip and poke it up in to the needle that the water comes out of on the top of the lid. Run the vinegar through the machine until the reservoir is empty. You can even let the vinegar sit in the coffee maker for 10-15 minutes. Refill reservoir with purified water and run the maker until all the water is dispensed and the reservoir is empty. There should be no more vinegar smell. Never use tap water. Do this every two months. Note: if the area where the K-Cup sits gets dirty with grounds, put a large bowl under it and then pour a glass of water over the whole area to clean. Also, on occasion just run a cup of water through the machine (with no coffee) just to make sure that there are no grounds caught in the needle. Done!
Feb 19, 2012 | Keurig B60 Coffee Maker
I want to drain my coffee maker to store it for a year or two.
Should be easy!
I'd recommend, first, descaling it by running white vinegar through it (per your manual). This will help remove any mineral deposits that may have built up. Follow this with running water through it... sufficient to get rid of the vinegar smell & taste out of it.
Then take it apart as much as you can & leave it on a towel on your kitchen counter to dry out. Give it around 24 hours. If you want it to be bone-dry before you store it, use a hair dryer (at low-heat or no-heat setting) in the water reservoir to drive out the moisture.
Finally, when you're sure it's clean and bone-dry, put it in a large zip-lock bag to keep out dust & bugs. When you're ready to take it out of storage, run water through it once (to get rid of any possible mustiness) and then you should be set for a great cup of coffee!
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
Sorry to read about your problem, I hope this helps you out.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ds
sdf
s
fs
f
Dec 22, 2010 | Keurig B60 Coffee Maker
Foul-smelling coffee
May 03, 2010 | Keurig Special Edition B60 Coffee Maker
B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 09, 2009 | Keurig B60 Coffee Maker
When trying to brew a cup of coffee it drips slow like it is clogged
Hi, RICHBURG511. Sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up (calcium) from the minerals normally found in your water. Do you use regular tap water or filter it in any manner?
When was the last time you de-scaled your Keurig? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Here’s the ‘poop’ straight from Keurig, direct. Just follow the links.
Good luck, I hope this helps! – Howard, Burke, VA
hslincoln
Dec 05, 2009 | Keurig B60 Coffee Maker
Water heats but doesn't empty from the resevcoir
Keurig vibrates loudly and water doesn't come out.
Nov 03, 2009 | Keurig B60 Coffee Maker
Keurig new with burnt plastic smell
We had the same problem with the Keurig 2.0. We ran many cups of vinegar followed by water and it didn't fix the problem at all. The only fix was calling Keurig and they replaced the unit. We had a real nice 460. They replaced the unit with an inferior 350. Smaller reservoir, B&W screen and some missing menu options and different color trim. However, it works.
May 28, 2009 | Keurig B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
1,364 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Lisa
Lisa
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
