Question about Hotpoint Ultima WF860 Front Load Washer
Machine displays F-05
  • terrib888 Sep 01, 2008
    Had noticed a damp smell coming from the drum and affecting the smell of clothes. Followed advice from wbsite to put it on a rinse and spin cycle - to no avail. Cleaned the inside of drum with detergent and tried again. Put clothes on a 40 degree wash but at the end, door would not open. Put it on a 30 degree wash and when I went back to it 'F - 05' showing on display - then started to flash.
  • 3 Answers
F-05 , pressure sw stuck on full this is a faulty switch
Posted on Sep 21, 2008
Machine has a fault code co me up on display F-05
F05 - Pressure switch jammed on full - Check pump for blackages
The fault is associated with drain out (pump blocked or restricted in some way).
Jun 19, 2011 | Hotpoint Ultima WF860 Front Load Washer
Machine flashing f 05 taken back cover off and cleaned hose,still not emptying of water, shall we give up or try something else? hotpoint ultima wf 860
make sure you have checked the pump itself, possibly a hairgrip/nail etc. jamming it. also make sure nothing blocking the actual waste hose itself.
Hotpoint ultima wf840, what does this mean F-05
F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Apr 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840
f05 meas not drained. usually due to a blockage in your filter.
you will need to get the water out by holding the drain hose lower than the machine into a basin. when drained the door can be opened. unscrew the filter and check for coins/socks etc.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine
f05 is a drainage problem, ther may be something stuck in your pump.
its in the back of the machine in the corner. take the side hose off and unclip the pump from machine and look in to see the propellor may have foriegn object in.
Dec 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860
Hiya got it sorted on my machine, it turned out that the out pipe was blocked. Hope this helps
Vikki
Apr 13, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT WT940P
Lower the outlet hose into a low bowl, if water flows then you need a new pump cost around 20 pound to buy, If no water comes out the you have a blockage somewhere.
Nov 29, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
223 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
