What OS? why in the world post lacking this key fact?
the 14 MS OS made. or linux or o/s2?
who's restore disk?, MS< , HP media kit, yours (DIY) what?
new hdd. Tiny.
really new or just new to you? came in a sealed box or ESD wrapper silver that is new, all else is NOT NEW.
COIN cell battery still good, most are not , and resets do not fix dead batteries ever.
HP shows RETIRED product, (like me.. super retired) 2005 PC?
Installs can fail vast numbers of way,
old DT.
can you boot to KNOPPIX live DVD?? yes /no. (all techs do this)
USB stick made.
http://www.pcdied.com/brick-dead.html#Knoppix
if that fails then the PC is dead. (ask what to do now?)
if knoppix DISK test fails, to the HDD (new) is bad.
yes all pass, then your XP install disk is junk. or DVD drive bad.
if you want use DVD-r and burn Knoppix there if the drive shows
read errors the drive is bad. ending this saga now.
I am not sure where to get XP on disk in 2017?
its a dead OS.. and a virus magnet worse each day forward from 3 years ago.
XP needs a disk or stick that is good.
most sold are junk or worse virus infected.
what disk do you have, what does the LABEL SAY
pretend we can not look over shoulder and go, all why use DELL disks? or 1000 other ah that is wrong..
why spend money on hardware this old? good after bad... ??
if you made your own recovery media, say how>?
sorry for 20 questions but it is a complex computer, after all.
-------------------spec----------------
spec... lean.
AMD Turion 64
ATI Radeon Xpress 200, GPU chip
1 x 1 GB ddr. 1 stick stock
200GB sata.
P/S2 mouse.
came with XP
5 USB ports.
Double Layer 16X DVD±R/RW drive
May you explain a bit more you've done? Was this your system disk?
Regards
Stephan
SOURCE: need to format the hard drive for HP Pavilion
If you own the computer and it is still in warrenty then i would call up HP and explain the situation and have them send you a recovery disk, if it is not in warrenty they may still do it but if it doesnt work your other option is to purchase one or to Pirate one which wouldnt be illegal if you used the product key that came with your computer.
SOURCE: Change HP Pavilion Slimline s7520n Video Card?
The on-board RadeonXpress 200M graphics is a dog. It offloads a lot of work to your cpu, and shares system memory which ties up the bus and detracts from the memory available to the OS.
The s7520 suffers from thermal problems due to it's size and poor ventilation. It also has a very limted power supply. Therefore, your choices are also limited. If you could score Radeon X600 or X1300 with 128MB for cheap somewhere it would be a worthwhile upgrade. It does need to be PCI (not PCI-E) and half-height (low profile).
SOURCE: audio and video driver installer for hp pavilion slimline s752n
You can download the drivers from the HP support site here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=uk&lang=en&product=3199127&
You will need to select your operating system e.g.Winows Vista, Windows XP etc. then select the download that you require.
If you need more help please reply to this message.
SOURCE: my compute (slimline s7520n) will show the blue hp
You may have a stuck Function key on your keyboard or Escape key. Make sure these aren't stuck and try a reboot.
