Question about Rowenta Professional DX8800 Iron
Turns off after 10-15 seconds. Shake and it comes on briefly
  • denicollie Jun 21, 2008
    My beloved Power Glide DM 273 will not turn on! Nada, nothing. Unable to take out screws. Help!!! denicollie@bellsouth.net
  • Anonymous Apr 07, 2009
    My Rowenta Professional DX8800 Iron also turns off after 20 or 30 seconds.
    New Friend:
  • 18 Answers
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
My Turbo Kirby won't turn on, bet it is also the metal plate on switch! After getting a Dyson, it's hard to cry over the Kirby, but I miss the carpet shampooer. The Bissel is just OK....
Posted on Mar 09, 2009
Gravity feed steam iron
If you have been using tap water in your iron, and your water has lime or calcium in it, then the iron is probably clogged up. You might try using a product like "Lime Away". Read the warnings on the bottle first. Don't get it on your skin or in your eyes. Don't breathe the mist or steam. The bottle I looked at also had warnings about how it would mess up some counter tops or sinks.But if the iron doesn't work anyway, carefully pour some into your iron maybe about one fourth full, then carefully shake the iron to get the stuff all over the insides of the iron holding the iron like you would if you were ironing. Let the iron sit for a bit, then shake it again, maybe a couple more times like that. pour it out into an old bowl that it wont ruin, and see if there are a lot of minerals in the liquid. If there are, that may have cleaned it enough to start working again. Pour enough water in the iron until it is half full, plug it in and turn the temperature up to where it will produce steam, but don't iron any clothes yet because there is still cleaner in the iron. turn the iron so it is like you are ironing, but don't let it touch anything. Hold it over something like some old rags. If steam comes out, don't breathe it, but let it come out for a little while. Pour out that water and refill with fresh water and let it steam over the rags again. Pour that water out and all the chemicals should be flushed out of the iron. Carefully wipe the hot plate off to get any chemicals off the plate. Good Luck
Nov 02, 2013 | Irons
How do I clean a rowenta DX8800 iron that leaves deposits on my garments
Use a white vinegar and distilled water solution in the iron, but don't do any clothes with it. Let it soak for a while, then heat the iron and let it blow out any debris. Fill again with distilled water, shake well, and let it steam out. Do this again until there is no vinegar smell coming out. If you use only distilled water, you should have no further problems like this.
Sep 18, 2009 | Rowenta Professional DX8800 Iron
I have no steam coming
port hole has hard water build up use half vinegar and water fill let set fo 30 min.shake it up pour it out and refill
Aug 28, 2009 | Tefal Ultraglide 1549 Iron
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Sand is coming out of the vent holes
Probably not sand but crystalized minerals from tap water. Heat up the iron then unplug it and add white vinegar. Shake it up and pour it out of the fill hole. Repeat if necessary. Then rinse it out with distilled or filtered water. Before using on clothes, fill with water and steam iron an old towel to get the vinegar smell out. Use only filtered or distilled water to prevent this happening again.
Jul 19, 2009 | Irons
While ironing with steam, scale deposits came out through holes. how do I clean iron
You can try this out, fill the Iron with a considerable amount of water, Switch On your Iron, Increase the heat controller Knob to the maximum so that the water boils and Place it Upside Down (As if you want to Iron) but dont let it touch the Pressing Table. Then keep pressing the button that disperses the steam until the whole water inside it finishes, repeat this same process over and over until it comes out clean...
(Alternatively however, you can just pour hot water though the water-inlet hole, and after a while, shake the iron and turn the water out upside down and let it pass out of the water-inlet hole...but please be careful with this second method though...because of the hot water)...hope it helps.
Jul 10, 2009 | Sunbeam 4214 Iron
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Jan 30, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Rowenta Professional DX8800 Iron Logo
594 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
