Question about ASUS P5VD2-MX SE Motherboard
I need Help
I have a pc..
motherboard was ASUS P5VD2-X..
First... if i open the power ...the words "dective none drive " appears and that will go on working... but...if i choose "Start Window Normally" and press enter ....The pc was automitically shut down.. i want to know what happen ....
    President:
  • 2,351 Answers
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Posted on Jun 21, 2008
What is the difference Asus P5VD2-X and ASUS P5VD2-MX SE Motherboard?
https://www.asus.com/Motherboards/P5VD2MX_SE/
http://www.asus.com/Motherboards/P5VD2X/
you can never have to little RAM.x32 max 4 gig x64 that depends on the motherboard.
uninstall all programs that you dont use or rarely use.
have so feve auto-startprogram as possible.
Feb 21, 2014 | ASUS P5VD2-X Motherboard
HI!Could you write me the graphics cards that supports the asus p5vd2-mx se motherboard?because i have a problem with asus 8800gts.when i fit the card,the pc doesn't boot up,while when i fit my old...
Its is possible that the power supply isnt powering the graphics card, because of the power needed to run the fan and gpu. It is a more updated card than the 8600gt with more graphics processing speeds and capabilities, so it is possible you will have to buy a new power pack with more wattage.
Jan 28, 2010 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX SE NO VIDEO AUDIO DRIVER
You can download your drivers at www.asus.com. Clcik on the support link and then lookup your specific board model # and input the operating system you are using. The site will then display all bios and drivers available for your board. Download and install the drivers you need and you should be all set. Hope this helps.
May 17, 2009 | ASUS P5VD2-MX SE Motherboard
I dont get any sound on my pc but he let mi see i have sound
Go to this link, and select your mobo, os, etc... it will give you links to download latest drivers.
Apr 02, 2009 | ASUS P5VD2-MX SE Motherboard
Impossible to instal driver ASUS P5VD2-X, 'boost driver' request?
boot drive right?. power off the system take off the power cord and then re-plug the harddisk cdroms and floppy drive if u have one. and see if it helps. and also remove any usb devices which are plugged into your system while rebooting.
Nov 29, 2008 | ASUS P5VD2-X Motherboard
ASUS P5VD2-MX SE sound driver
you can download the audio driver for your motherboard from some of the sites given below ...
http://www.nodevice.com/driver/P5VD2-MX/get34077.html
http://www.nodevice.com/driver/company/ASUS/Motherboard.html
http://www.driverstock.com/ASUS-P5VD2-MX-driver-download/6-9-10181/index.html
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Sep 02, 2008 | ASUS P5VD2-MX SE Motherboard
Vga compatibility
It appears that that model is AGP slot based, so it would not work in a PCI slot.
Aug 31, 2008 | ASUS P5VD2-MX Motherboard
NEED A MOTHERBOARD SUPPORT
Follow the link: http://support.asus.com/download/download.aspx
PRODUCT: MOTHERBOARD
SERIES: SOCKET775
MODELS: P5VD2-MXSE
You'll find everything you need.
Nov 11, 2007 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX SE Motherboard Logo
196 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
