Question about Dishwashers
BEKO D 2731 FW Dishwasher Problem
The drain pump operates continuously on our dishwasher. Nothing else happens although the programmer is clicking away but doesnt seem to move. Can you help please
  • 1 more comment
  • Bev Pyke Jun 21, 2008
    Wow it worked. Thanks so much - we were going out tomorrow to buy a new one!
    You are a star !!
  • Anonymous Dec 27, 2008
    not draining properly, works when i tilt it 45%, but same problem returns after one or two washes. also program ticks on ,but dial does not move.
  • Anonymous Apr 28, 2009
    the pump runs but the dial does not rotate or move to its next stage of wash.no water appears inside machine can u help?
    President:
  • 1,462 Answers
Possibly due to water in the sump tray. tilt machine back at 45deg and see if water runs out. if it does and you get rid of the water that way, then the machine should operate. if it reoccurs, then you have a leak
Posted on Jun 21, 2008
Ours stopped mid cycle tipped 45 degrees and now it works
Posted on Sep 13, 2010
Hi, after 3 years storage for washing tablet never opened during any programs!
Hope, you have got any idea what to do. Thanks
Posted on Dec 30, 2009
Yes man,it worked 1st time,cheers for that info.
Posted on Sep 28, 2008
Stops working part way through programme
It seems it is drain problem and check out your drain hose and drain pump for problems and clean all main motor and pump as much as you could do
Dec 09, 2013 | Siemens 24 in. SE25A266 ExtraKlasse...
Beko dishwasher not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Beko 24 in. D3421F Free-standing...
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Beko DE 2431 FW dishwasher
hi there.....when the machine brings water in...have you cancelled the program reselect a program and checked that it is puming out..if all is ok then you need to check that the main wash pump rotates freely....if all is ok here..then i suspect you have a failed capicator on the wash motor....little white cylinderical component on top of the motor
regards Sir Galahad
Jan 20, 2009 | Beko 24 in. D3421F Free-standing...
How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
Nov 30, 2008 | Beko 24 in. D3421F Free-standing...
Dishwasher not working
dishwasher dwd 3410 w,it runs normal to the end but doesnt drain the water
Mar 25, 2008 | Beko 24 in. D3421F Free-standing...
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
1,144 people viewed this question
Top Dishwashers Experts
