Question about RCA P61927 61" Rear Projection Television
RCA P61927 61 in. Rear Projection Television
I have same promblem - Where can i get parts to replace power supply
Tv won turn on anymore, checked fuse is fina..... i read another post you posted saying u need to replace convergance module or something... where can i get the parts or would it be cheaper to get a tv repair man. thanks contact mat/hitdesigns@yahoo.com
  • motostine Jul 11, 2008
    Will not turn on. Makes a clicking sound when plugged in.
    Genius:
  • 2,920 Answers
Get a tv repairman out to make sure of the problem, it might be xomething simpler he can fix but it sounds like the convergence board is out
Posted on Aug 23, 2008
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca projection tv will not turn on
hello, do you mean no power at all if have you check the glass fuse inside the tv in the power supply if it's black in colour then it's blown make sure you use the same rated fuse the value will be on the end of the fuse or on the fuse holder on the circuit board
regards
shaun
Nov 21, 2010 | RCA D52W19 52" Rear Projection Television
The tv won`t turn on. its it a fuse
Do you mean is it a fuse? Because if the fuse is blown that means more than likely there is something else wrong with it...probably in your power supply. What I recommend is to plug it in and listen for power (high pitched buzz), if you cant hear that...it could be anywhere from a diode to the HOT. If you have an om meter, I suggest checking thos first. What happened before it went out? and are there any LEDs that turn on in the front?
Aug 05, 2010 | RCA MM52110 52" Rear Projection HDTV-Ready...
My T.V. won't come on.
I would guess that the HV Block has failed. A very common failure. I would hesitate trying to replace it unless you are familiar with Projection HV circuits. You did good supplying
the Model # and Chassi #. both are required to get the proper part# if you try to get the part yourself or calling a service shop to fix it.
Hope this helps,
Skyassoc
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
Rca p61297
Sounds like you have a bad convergence power supply reg,part number is 215530,unplug the set remove the back cover on the right side above the module with 6 heat sinks,is were the pwr. supply is located,the part is on a heat sink on the board
Dec 02, 2007 | RCA P61927 61" Rear Projection Television
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
RCA P61927 61" Rear Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
