Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Battery? I have a Macbook with leopard, only a few months old. A few days ago, it wouldn't turn on. So i figured the battery wasn't charged. I plugged it in to the power adapter and it turned on. But the battery status is "not charging" and it remains at 0%. I removed the battery while the power adapter was connected, and that did nothing, I also removed the battery while the Power adapter wasn't connected. There are some other minor things that happen also, occasionally the application "Photobooth" will not open. I have problems with it opening websites occassionally, even if I have full wireless reception. And for the first 2 days that I was experiencing this battery problem, the help chapter on battery status "not charging" in the help program would not open.
  • alfez5 Feb 11, 2009
    my battery wont charge either
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Could be a disc error. Make sure your battery is in the correct way as it can go in 2 different ways. Line the slots on the battery to the prongs on the laptop. Before I go on, it may be you battery is dead for some reason?
Go to applications folder, find disc utility and hit "repair disc" it will come up with ANY problems your computer is having. You will then have the option to "fix errors"
Try that.
Posted on Jun 23, 2008
2003 Saturn Vue with a identity anti theft system. Replaced my battery a few months ago. Couple weeks ago noticed a little difficulty starting up. Last week wouldn't start just clicking noise. Jumped...
Anti-theft system has nothing to do with it . Battery cables , maybe , Park neutral safety switch possibly ! With anti-theft system problem you wouldn't a click or anything , that is if the anti-theft disables fuel or the starter . Plus the SECURITY light would be on if it were a anti-theft system problem . Your best bet , take it to a qualified repair shop that knows how to do starter circuit testing >
Starter Voltage Drop
How to voltage drop test starter motor circuit
And what's this identity anti theft system ? No such thing ! The vehicle has a content theft an vehicle theft deterrent system !
This system disables fuel not cranking of the engine. The VCM/PCM will not disable the fuel due to any BCM message for the remainder of the ignition cycle.
If the VCM/PCM does not receive the same password from the BCM as the last learned one, the vehicle will start and then stalls due to the Fuel Lockout.
May 17, 2017 | Cars & Trucks
Toyota Echo Won't Start
check starting system. as you said, you were be able to start when it push.
and if you notice when ignition is on the engine not cranking, starter is the sure problem.
May 27, 2013 | Cars & Trucks
1988 lxi honda accord battery drains overnight
Just a couple problems I've had. dome light left on due to faulty door open switch, spot light charger or equipment left plugged or wired to battery, lately I thought I had a bad battery but I just need to clean the terminal connections. One more thing if your car is running you can pull the negative cable off the battery. If the car dies your alternator could be the problem. If you have a light in the trunk or under the hood you could pull the bulb out to make sure you don't have a faulty switch turning them on. These are kind of simple and that is the way I start out.
Jul 04, 2017 | 2007 Honda Accord Sedan
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
2001 BMW X 5 replace battery now it wont start
Starter solenoid. Put a new starter on it and try it out.
May 05, 2010 | 2005 BMW X5
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
Macbook Battery Problems
Hi Molle
To answer your last question first. It is best if possible to use the mains power when you are using your macBook and only use the battery when you cannot connect to mains.
MacBook batteries have a life span based on the number of charge cycles the battery has been through. The battery has a max of 300 cycles before it starts to loss its charge capability. SO you need to determine the health of the battery is it chargeing etc. You can do this via the apple menu and 'about this mac'
Check the health of the battery as the battery could be faulty if it has only cycled a few times or it may have gone over the 300 and is now lossing its charge in which case you'll need to get a new one.
Hope that helps
Sep 04, 2008 | Apple MacBook Mac Notebook
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
115 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
