Question about Palm TX Handheld
Check power button reply
What power button... the palm is with power and so is the computer...
Paul
  • 1 more comment
  • SaintPaul Jun 21, 2008
    Hotsyn Manger will not open.. whenUSB from palm tx is connected it beeps and shows unknown on device.. cannot hotsync
    Paul
    Hotsync Mangaer will not open,checked properties and got the right setttings had to go to Windows 2000 yet I have XP.Now when I plug the USB in the computer beeps and devices blinks. Cleaned contacts no luck. Same symptoms..
    I just plugged the usb in and beeps...
  • gopinath pasupathy May 11, 2010
    what is your problem
    Master:
  • 848 Answers
Let me see that one and tell you
Posted on Jun 21, 2008
SprintScan 4000
paul here i am, what happened, you suddenly ended our session, do you still have the script? we can continue it there if you want. just watch out for my reply.
Jul 30, 2008 | Polaroid SprintScan 4000 Film Scanner
On Palm TX Hotsync Manager will not open
check whether the power supply is proper
Jun 21, 2008 | Palm TX Handheld
I have a FinepixJ40 with the ZOOM ERROR and tried to turn the lens several times, still can't fix the problem, is there something else I can do? Thanks Paul
try when u push the power button to twist the lens and see if it works...if not try pushing on the lens when pushing power button...i have fixed some while pushing power button and giving it a little hit with the palm of your hand..hope this helps
May 05, 2011 | Cameras
Handheld will no longer hotsync. I think the program was corrupted on the computer and I accidentally deleted one of the files. I'd like to download another program and reinstall it on my computer.
Hi Dr.Coldoff,
Please remove and reinstall the software to see if it works. Or else try to reset your Device:
How to reset the Tungsten E2
1 Press and hold the power button.
2 While holding the power button, use the tip of the stylus (or a similar object
without a sharp tip) to gently press and release the reset button inside the hole
on the back of your handheld.
3 Wait for the Palm Powered? logo to appear, and then release the power button.
4 When you see the message that warns you about erasing all of the info on your
handheld, do one of the following:
* Press Up on the 5-way navigator to finish the reset and show the touchscreen.
* Press any other button to do a soft reset.
In case you are facing any difficulties, forward me your email ID and I will reply to it
Sep 29, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I have just bought a replacment Z22 tried to hot sync fom PC and it closed the Z22 down and will not come back to life why?
HI,
I had the same problem with my Palm TX. What I did was to first make sure I had the most up to date desktop software. I got this from Palm.com. I found that I did have the most recent software version so my next step was to do a hard reset on my palm. Make sure you have all your information backed up on your computer before doing the hard reset! To do the hard reset here are the steps:
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
After you do this try the HotSync. Your z22 should sync with all the info from your computer. Best wishes.
Aug 24, 2009 | Palm Z22 Handheld
Hot Synch an existing PalmVx data to a replacement palmVx
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Dec 12, 2008 | Palm Vx Handheld
I cannot turn my Palm 500 on the light just stays green
Have you tried to reset? Turn your Palm over. On the back side there will be a little indentation for resetting the device. Take your stylus and push the button inside the indentation.
Did this work?
No, then leave it on, (assuming it is on because of the green light) and let the battery run out of power. When it does run out, the light should go off. Plug your Palm back in to power to recharge and see if it comes back on normally. If it doesn't, there is one last thing you could try. Your manual will explain how to do a full factory reset. If it doesn't, reply back to this post and I will explain how. Binary Bob
Nov 15, 2008 | Computers & Internet
Hard reset
1 Hold down the power (on/off) button on your device. 2 While holding down the power button, turn over your device so that you can see the back of it. Still holding the power button, use an unfolded paper clip or a similar small object, to gently press the RESET hole on the back. 3 When the Palm Computing Platform or Palm Powered logo appears, release the power button. 4 A message will appear warning that you are about to erase all the data stored on your handheld.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Hard reset
Sep 15, 2005 | Palm LifeDrive Handheld
Palm TX Handheld Logo
16 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
