Question about HP PSC 2175 All-In-One InkJet Printer
Colors become lighter toward end of print
I am printing a page that is somewhat color intensive. It prints fine, no matter how many times I do it, for a while, but the last 1/8th of a page loses the colors and creates a rainbow effect rather than the full color I am expecting...Any ideas? Thanks
  • Hamlet1973 Jun 21, 2008
    Actually, thank you for your help, but I was printing from a digital image online. It turns out that I needed to change my "Print quality" from normal to best. That solved the problem. Thank you for responding.
Yes, the original image may have been released too soon from the scan image input. check the original and see if the color is lighter. flip the image bottom to top and run 1 copy to see if the problem is still there in that location. if it is, then you have a backlight burnout occurring or dirty glass area.
Posted on Jun 21, 2008
How to clean the printing head of brother mfc-210c after a long-long break in usage?
Unfortunately this is a very old model and when the Printhead stops firing ink, you cannot repair it. Better buy the new MFCJ470DW which is the 4th Generation of your machine and not expensive but very good machine
Jan 14, 2015 | Brother MFC Office Equipment & Supplies
HELP- Hi my CLX-2160 prints a fine clean textpage - copy function in B/W is also ok - print sharp, well formed,characters - BUT COLOR COPIES ARE PRINTED TOO DARK - printing color from photoshop or other...
there is small preset in LSU pcb (laser scanning unit) exist at lower side of printer for laser intensity
try to adjust that preset slightly low level (anti clockwise)& check the result both color & b/w
Feb 10, 2011 | Samsung CLX2160 Multifunction Color Laser...
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
Color intensity= poor
Shake the cartridges well, it seems that they become dry, try to replace them and check again, go to driver there is setting makes u clean and test the nozzels which makes the color more rich and at the same time it check the state of the cartridges.
Best Regards
Mar 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Epson 1290 (Suzie Tisch)
Try printing a test page by going to Start>Control Panel>Printers then select the printer, right click for Properties and click on Print test page. Inspect for all colors. If all colors are present then check the resolution settings. Which application are you printing from?
Oct 21, 2008 | Epson Stylus Photo 1290 InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
