Question about Olympus D-555 Zoom Digital Camera
Printer paper and cartridge
Does anyone know where I can get refills for the paper and print cartridge for my printer? I've looked on line at all the hits I get. Please help.
    President:
  • 919 Answers
Target carries the PH-40 and the PH-160 printer packs for the Imagelink printer. These are products that are made by Kodak as it is originally a Kodak printer.
Posted on Dec 19, 2008
Canon Pixma MX300 won't print black anymore! How to fix?
I have used "refill" kits in the past and for the time and effort involved you might just try finding a local retailer that will give you credit for the empty cartridge to replace with a professionally refilled one.
The problem with refilling the same cartridge over and over again is that they will, eventually, need to be replaced. I would suggest that you
1 - Make sure there is nothing plugging the hole at the top of the cartridge to allow air in, which is needed to let the ink flow out.
2- Install another cartridge and you get the same problem, then it narrows your fix to something with the printer.
3 - If it is the printer, I were rubber gloves and use "denatured alcohol" and a rag (no not use anything with paper as it can tear and leave pieces inside causing the printer to jamb) and after removing all of the cartridges wipe down anything that I can reach inside the printer.
4 - Although you have tried the DEEP CLEAN, if the none of the above works for you, try the NOZZLE CLEAN. If you are still having a problem then either re-post the problem or doe a Google Search listing the model of the printer you have, you may find out it is a problem that others have experienced and there is no solution.
Good Luck
Apr 06, 2013 | Canon PIXMA MX300 All-in-One Printer
When I put the paper in, and push the refill button, the paper goes down in the printer crookid, I need help does anyone know what I could possibly do?
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Oct 07, 2011 | Lexmark X2500 All-In-One Printer
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Pixma mp150 error code 5
This error 5 appeared. Need to know what it is and how do we fix it. Help!!!!
Aug 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP140 Service error 5100
ok... you have to reset the printer --
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Hpoe this helps
Jul 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
IBM INFOPRINT 1120
Julie1665, Here are some things that could be causing your problem: -Could be the paper you are printing does not meet the printer specifications. -Could be toner leaking out of the cartridge. -Could be environmental issues, too hot or cold or humid. -The toner density could be set too high. -The electrical contacts that connect the toner cartridge to the printer could be dirty or just not making good contact. -the printer power supply could be defective. -With regards to your toner cartridge are you using new IBM cartridges or refilled/remanufactured? I?ve had many customers call me to fix a printer problem that turned out to be a bad cartridge. All of these are within the capabilities of the typical user except changing the power supply. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 22, 2007 | IBM Infoprint 1120 Laser Printer
Test print great, document printing blurred
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Sep 02, 2006 | HP DeskJet 3325 InkJet Printer
Olympus D-555 Zoom Digital Camera Logo
204 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
