Question about Pioneer Audio Players & Recorders
Need to replace a fuse on a Pioneer CDJ 200 - Pioneer Audio Players & Recorders
  • 1 more comment
  • diamonddan11 Jun 21, 2008
    yes
    I need to replace the fuse it has no power when pluged in where is it and how do i do it
    I need to replace a fuse on a pioneer cdj 200 when i plug it in and turn on it has no power at all. I think it has been pluged into the wrong power voltage which has caused this proberlem
    Master:
  • 638 Answers
All the wiring instructions are as follows:Red=Positive 12v(switched)
Black=Negative ground
Yellow=Constant Power(Battery or fuse box W/ Constant power)
Grey=Right front+
Grey/Black=Right front-
Purple=Right rear+
Purple/Black=Right rear-
Green=Left rear+
Green/Black=Left rear-
White=Left front+
White/Black=Left front-
Blue=Amp turn on
Blue/White=Power antenna
Orange/White=Dimmer
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 21, 2008
    Master:
  • 848 Answers
Just see the manual and replace the fuse
  • 1,512 Answers
There is no fuse for the user to replace on this model. What has happened to the unit.
regards
robotek
  • 4 more comments
  • Graeme Ross
    Graeme Ross Jun 21, 2008
    If your unit has stopped working and appears to be no power, the power supply has ceased working and will need some repairs. If you understand electronics, I could talk you through how to faultfind the deck
  • Graeme Ross
    The fuse is located on the power socket to the rear of the unit internally.
    There is also a thermal fuse inside the transformer.cThis may be causing you problems.
  • Graeme Ross
    There are also 5 or six Pico fuses that look like transistors on the PCB attached to the secondary of the transformer. Any of these may have failed preventing the unit from working also.
  • Graeme Ross
    You will need to use a multimeter n low ohms range to check all of the fusibles. Be sure to disconnect from the power before doing anything!
  • Graeme Ross
    The 2 pin circuit protector type pico fuses that are marked as IC.. are in many places in the unit. You need to look for all of them and check them all. There is another one on the power regulator board.
  • Graeme Ross
    Graeme Ross Jun 22, 2008
    I have indicated to you where the fuses are inside the unit. In summary
    1. mains power fuse FU11 is located INSIDE the deck on the same circuit board and the mains on off switch.
    2. There is a thermal fuse that is not changeable inside the widnings of the transformer. This is can be repaired but generally it is considered that you replace the transformer
    3. on the printed circuit board attached to the secondary side of the transformer you will find 5-6 pico fuses, or circuit protectors. The are small black 2 pin devices that are marked on the board as IC901 to IC905
    4. the main power regulator board REGB ASSLY also has a circuit protector IC911.
    5. Thjere are several others in power supply areas marked as IC907, 908, 909, 910, 913, 914.
    OK, thats a run down of the fuses in the unit. Non are considered to be user replaceable parts.If you replace the mains primary fuse, FU11, and the unit still does not work, you will need to take it to Pioneer Service. If the deck has had the wrongvoltage
  • 4,472 Answers
Http://www.eserviceinfo.com/downloadsm/26076/Pioneer_CDJ-200.html
You can find the complete service manual here it will give you everything you need. Make sure to download all 5 files first before you extract it.
Let me know if you need anything else,
Lee
    Genius:
  • 3,422 Answers
Can you please describe your problem so that we can help you fix it.If you need a service manual then please CLICK HERE
Please don't forget to rate or accept the solution.
    Sergeant:
    Champion:
  • 230 Answers
Do u need to know where is the fuse??
  • balachander megavarnam
    balachander megavarnam Jun 21, 2008
    usually the fuse will be located in sides and also at the bottom open
    that and take the fuse ,if it is blown ,then replace the new fuse . The
    main thing you should keep in mind is ,the replacing fuse should have
    the same value as the blown fuse
    thanks for using fixya
    you may press accept button on my solution if you are satisfied
  • Pioneer Master
  • 13,433 Answers
OK, what do you need?
  • 2 more comments
  • Ekse Jun 21, 2008
    you can read the fuse valua on the old fuse, you have to open it and locate the fuse. then buy one with same values.
    do you need anything else? please comment back or reply.
  • Ekse Jun 21, 2008
    Please wait.
  • Ekse Jun 21, 2008
    Here is the service manual for your product
    http://koti.mbnet.fi/exuli/CDJ-200.pdf
  • Ekse Jun 22, 2008
    Please request more assistance / repost the problem untill you see the solution posted by robotek.
Manual for a pioneer cdr 200
www.manualslib.com/manual/699716/Pioneer-Cdj-200.html#manual this is a good choice for finding your information. www.manualslib.com in the seach box enter Pioneer-Cdj-200.
Nov 24, 2017 | Pioneer Audio Players & Recorders
CDJ 200 meant for US mains supply plugged directly into UK mains supply, now don't work. Replaced external fuse but still don't work..anything else i can try before i bin it?
Dont bin it!!!
If you are really lucky it may have just blown an internal fuse or if your not so lucky it may have killed the mains transformer which is still worth repairing.
If the transformer is faulty and was replaced with one sourced from Pioneer GB then no external 240V to 110V transformer would be needed - you would be able to plug it straight into a UK mains supply.
Jul 20, 2010 | Pioneer CDJ-200 CD Player
I have a CDJ 200 cd player the power when turned on there is no display YASH
Hi Yash,
pls make sure and check the fuse of your CDJ. Also check the power output that is 240v or 110v.
thx,
djajay
May 25, 2010 | Pioneer CDJ-200 CD Player
No audio on cdj 200 after a power failure
check the fuses to see if they are any good
Feb 17, 2010 | Pioneer CDJ-200 CD Player
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
I have a problem with one cdj 200.some gear in the cd player have problem and i can't put out the disc,have you see the same problem again?
There should be a pin on the bottom of the cdj, this is the push pin that will manually release the cd inside. BE CAREFUL!. This will work much like the pinholes in cd trays on computers. Just push it in to release the jammed cd. This may not work, and is only a suggestion. If this does not work, I'd attempt to contact Pioneer directly for a service request. Hope this helps!
Jan 07, 2010 | Pioneer CDJ-200 CD Player
Pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
May 19, 2009 | Pioneer CDJ-200 CD Player
CDJ 200 without electricity fuse blow off?
no you cannot do that , the device works on 120v( 117v around me) , but it cannot be changed like that , you would need a trans former that breaks down the voltage to 120v
changing the fuse will not change the circuitry in the device
Nov 30, 2008 | Pioneer CDJ-200 CD Player
Pioneer cdj 200
the fuse was blown inside!!
Aug 11, 2008 | Pioneer CDJ-200 CD Player
Cdj 200 will not turn on
It actuall might be the fuse or there is a little short circut switch on one of the boards. That switch could have gotten moved.
Nov 20, 2007 | Pioneer CDJ-200 CD Player
197 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
