Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Touchpad how do i disable touchpad when using an external mouse?
  • 67 Answers
PRESS FN+F4 AND CHECK IT
Posted on Jun 21, 2008
    Sniper:
  • 65 Answers
It is not needed when u attach ur external mouse it starts running wid it....why it need to be disable.
but if u need....
if ur havin touchpad driver installed in ur laptop then u can disable it frm it...
ask me if ur havin more problems........
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
I am using a Dell Vostro 1220 laptop. While composing a mail or on working on Excel, many times the pointers and controls are going haywire deleting the contents, replacing the texts, etc. What is this...
first, make sure the latest touchpad driver is installed. after that, go to control panel, click the mouse icon and on the mouse properties, you should see a touchpad tab where you can find the option to disable it if you use an external mouse. hope this helps. feel free to rate its usefulness
Feb 10, 2011 | Dell Vostro 1220 Laptop Computer PC...
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Can't disable the touchpad on new laptop DV73020SA so that I can use a mouse
Start..Control Panel...Mouse ...click disable tap.
if it's not there, you will have to Update the Touchpad driver.
Oct 28, 2009 | HP Computers & Internet
Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Dec 11, 2008 | Computers & Internet
Mousepad
if you want to disable mouse (touchpad), use Fn+F7.
as you said your touchpad create problem, try to remove battery first (boot up using only ac adapter), battery can cause touchpad not working properly.
Apr 12, 2008 | Acer Aspire 3000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
335 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
