Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Hi troylove I have a WD52725 TV. Solid Red Status light. Error Code 44. Can you provide me with assistance on resolving this issue? Thanks, Frank
  • 31 Answers
The dvi cable could be bad in the set or needs to be sited. or one of the boards the dvi connects to. ( would bet it will be the DM board in the Chassis) it will need to be sent off for repair if it is the chassis.
Posted on Aug 14, 2008
What is Mitsubishi DLP TV error code 44?
That is an Open(blown)
Check for open F9A06 on the Power PCB
Sep 15, 2015 | Mitsubishi Televison & Video
The power light is solid red with no light on the status. I took out the bulb and put it back in now I have a solid red on the power and a solid yellow on the status. There is also no sounds coming from...
steady red with yellow/orange status light indicates that the temperature is too high, so by the sounds of it your device has malfunctioned, you need to get a repair on this
see page 44 here
http://vis.mitsubishielectric.co.uk/files/library/files/hc3800_manual.pdf
different model but same error code
Mar 06, 2011 | Mitsubishi HC3000U Multimedia Projector
My projection tv lost its blue tint
Hi
Thanks for using FixYa. Usually this happens when the Light Engine has gone bad, and I should say this is a common issue with Projection TVs. There are three tubes/mini LCDs inside your TV- green/yellow, blue and red. When the set heats up over time of usage the screens tend to break resulting in leaking color everywhere. The cost to get this fixed by a professional should be around $300 depending on the parts that needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 23, 2010 | Zenith E44W46LCD 44" Rear Projection...
The computer has lost internet connection.
Hi
Thanks for using FixYa. Please check that the internet signals are being received through your Dell Dimension. You’ll need to left click on the Network Connection icon in the bottom right and then click on the Network and sharing Center and click on the status and you will be able to see the status of your network connection. If there is any red (x) mark against your computer, network connection and internet, then you’ll need to click on this sign to diagnose the error and resolve the issue.
Thanks
Rylee
Nov 19, 2009 | Dell Dimension 3000 PC Desktop
What does the red status light mean.
Unplug the Printer and again Turn it back ON after few minutes. A Solid Red Light Status means that, more than often it is for Paper Jam.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Brother HL-5240 Laser Printer
I have a wd65100 when powered on i get steady orange light then status blinks red & green,unpluged for 1 hour tv is working but dark picture
Hi
This issue can be due to ballast fan, lamp or high temperature. However, to figure out this we'll need to check for the TV from inside(wiring & testing the components) or the other way is when the lights blink again then follow the procedure given. After you turn on the set, and get the red blinking lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 4 flashes, then 1 flash = 41.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Thanks
Rylee
Jul 28, 2009 | Televison & Video
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
