Question about Toshiba Satellite A135 Notebook
Laptop beeped once as it shut down
My Toshiba Satellite A135-S2426 laptop has given me some troubles in the past, so whenever something out of the ordinary happens, I overreact. This isn't a very serious problem (I don't think...), but I would still like an answer.
So last night I was shutting down my laptop, and right before the screen when dark, it beeped once. I (being the worrywart that I am) turned it on to make sure nothing had happened to it. Everything was fine. So I shut down the laptop again, and it still beeped once.
Could somebody please tell me what's going on?
  • graykitty101 Jun 21, 2008
    The beep has never been there before...It's only just started. but it's good that somebody thinks that it's nothing. Phewf!
  • Lee A.
    Lee A. May 11, 2010
    It should be nothing are you sure you never had the beep before?
    Thanks,
    Lee
  • 4,472 Answers
Ya its a computer they are built to fail =). 1 beep is usually a normal sign. when you start hearing more then 1 beep then I might worry.
If you found this helpful I hope you will rate accordingly. If you have anything else ever in the future you can use the ask me feature at
www.fixya.com/users/leethedeuce
Thanks,
Lee
Posted on Jun 21, 2008
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
My Toshiba Satellite A135 laptop just started beeping. regular sounding beep every 15 seconds or so. please help!
Hi
could it be because it may be telling you that the battery is getting very low and that you need to plug in and charge
my toshiba laptop does it when its very low
Apr 29, 2011 | Toshiba Satellite A135-S2246 Notebook
Hi!, thanks for helping me Toshiba laptop satellite a135-s7402, what's the key to run the recovery at start?
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
Thanks,
Viju
Apr 06, 2010 | Toshiba Satellite A135-S2326 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
http://www.ccfldirect.com/lcdtutorial.html
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Try disconnecting power adapter and removing battery for two minutes. If the laptop still does not boot then there is an hardware problem. You can try taking out and putting back ram modules, but my suggestion is to take the laptop at a repair shop, if you cannot fix it by removing battery.
Jul 29, 2008 | Toshiba Satellite A135 Notebook
Toshiba satellite laptop
You can check your power options properties. Choose never of the turn off monitor, turn off hard disk and system standby... On your Desktop, right click and point to properties and point to screen saver you can see the power tab. click it and you can see the power options properties window. If the settings set same as i given. The battery of your laptop must have a problem.
Jun 23, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135 Notebook Logo
133 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
