Cd jammed - Audio Players & Recorders
Not much data provided to assist, generally you will see a small hole in the faceplate, insert a paperclip or small wiring until it clicks the release tray.
Posted on Jun 21, 2008
6 disc cd changer jammed in 2004 mercury mountaineer, says error when i try to eject or play jammed discs.
personally I used another not so valuable CD to push the jammed CD back, it appears the ejected CD may bump the open exit gate and get stalled. It has happened several times. Good luck
Mar 15, 2011 | 2004 Mercury Mountaineer
I have a 2001 Nissan Skyline 300gt and there is a cd jammed inside any soloutions please
Seems you have mechanism problem with CD changer. Firstly, need to taken out your CD changer and remove your jammed CD. Clean and check the mechanisms. Then re-try your CD.
Regards,
Dec 16, 2010 | Boss Car Audio & Video
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Oct 23, 2009 | 2002 Honda Accord
Jammed cd
Remove the cd player, or have a best buy installastion center do it. The cd can only be removed with the deck out of the dash, if it's jammed that bad.
Apr 22, 2009 | 2002 Lexus SC 430
I misplaced my i-mate jam istallation cd drive
i lost my driver cd , can i download for free?
Feb 26, 2009 | i-mate JAM Pocket PC
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Deneon UD M50 - Tray jam
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Nov 01, 2008 | Denon D-M50S CD Shelf System
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
CD jammed in player
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent. regards Mark www.carradiospares.co.uk
Aug 05, 2006 | Alpine CHM-S630 6-Disc CD Changer
48 people viewed this question
 Grubhead
Grubhead
