Logitech LX 5 mouse
Mouse freezes...only way to fix it is to unplug and replug in the USB cable ...this is a hassle...to you have real fix
  • 2 more comments
  • rekandjek Jun 21, 2008
    It is a logitech LX 5 mouse
    Why does the mouse freeze...
    I have already done what you requested and the mouse still freezes at random times
    The mouse freezes randomly...sometimes in the same day...sometimes not...I understand why you suggest this but it is not very practical
  • 6,487 Answers
Best way to check what if the mouse if faulty or not is to use it on a different pc and do the same thing so you should be replacing that mouse already becase there can be some problem inside..But if that mouse have the same problem on other PC a software update should do the trick for it..
Hope that helps........
Posted on Jun 21, 2008
  • Mark Gil
    Mark Gil Jun 21, 2008
    Ok but you can try my suggestion give it try and inform me what ever happen...if the transmitter is connected via usb try connecting it to ths PS2 port so we can also check that...
    Genius:
  • 1,447 Answers
Hi-
did you check for the software updates for your product? check this link just click HERE
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 21, 2008
    heres the the link for a step by step instruction for you to update your setpoint
    http://logitech-en-amr.custhelp.com/cgi-...
    Edgar Allan Pagayona Jun 23, 2008
    Two things-
    A bug might on the computer that causes it to freeze when you have the computer on even when you are not using it.
    if sleep mode is active try going to control panel and go to power options and disable sleep mode or put hibernate to disable..
    2nd is that there might be a problem on your USB drivers
    Best i got
    President:
  • 2,712 Answers
Try reinstalling the SetPoint software first, and try a different port.
To get the latest version of SetPoint, please go to the Logitech Downloads Page.
Try this article as well from the Logitech Knowledge Base, and let me know how it goes:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
    Master:
  • 848 Answers
Just tell me about the make of your mouse
    Genius:
  • 3,422 Answers
HI,
Did you try plugging it into a different USB port and see if you face the same problem And also try reinstalling the drivers.
  • Priya darshan Jun 21, 2008
    Try using a different mouse to see what happens. If the problem goes
    away, the solution is simple. If it doesn't, you've ruled out the
    possibility that the mouse is defective.
G 500 logitech freezes intemittently
I think i found the solution to the Logitech G500 mouse freezing problem: the 5-pin USB cable uses an embroidered thread of fine wire for the first pin on the left (black cable at the internal connector inside the mouse). These fine threads tend to break over time due to movement of the cord, it usually brakes by the point were the cord exits the mouse casing. what i did was actually very simple: I Opened the mouse (there's 5 screws you have to remove: 2 over the optical sensor, one underneath the sticker on the center, one on the right, and one at the bottom of the mouse), then remove the scroll wheel (and basically remove every screw you see on the inside of the mouse), there's also a pin holding the scroll wheel in place, remove that too. Now remove the circuit board and detach the USB 5-pin connector. Inspect the cable (you might have to remove some of the protective cover), if you find that the embroidered wire is broken, as i did, then proceed to twist the fine threads of wire on both ends, and then twist both ends of the broken cable togheter. Obviously the resulting cable is a bit shorter than the others 4... not a problem! simply align all cables and twist the excess wire forming a circle, and just tuck it in at the bottom casing of the mouse when you put it back together. This solution might not be the most clean and professional (perfect solution would be to replace the cord), but it only took me 15 minutes, and my G500 mouse is working perfectly since; hope it helps!
Dec 23, 2011 | Logitech G500 Mouse (910001259)
The cursor on my pc freezes..
Temporary Solution
1) Click Start, then Click Control Panel
2) Double Click Mouse
3) Enable the cursor trail
You will be able to see your mouse, even after the original cursor freezes on screen.
Steps that can fix the problem.
This may also solve your problem. ONLY do if you are sure that you know how.
1) Right Click on MyComputer icon. Then Click Properties.
2) Click on Hardware Tab, then Click on Device Manager.
3) Uninstall your mouse AND keyboard. Connect your mouse directly to the USB.
Then reboot your computer (restart) and let the mouse reinstall automatically.
Keep your computer in shape and you will have less problem
May 31, 2010 | Computers & Internet
There isn't connection between the wireless mouse and laptop
First, reload the softwear than came with the mouse. Then, check the cable connections from the receiver to your laptop. If USB, then unplug and replug, if PS-2, unplug, replug, make sure the cord(s) are seated fully in the laptop. Then change the battery in the mouse, push the connect button on the mouse, and you should be back in business. I have Logitech wireless keyboard and laptop and have not had any problems after reinstalling and checking batteries and initiating the reconnect button. You will see a small window on your screen saying the mouse is connected on Channel 1 or 2. I hope this will help you.
Sep 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Where do I find another USB receiver to my LX 8
Try contacting Logitech for the replacement of the receiver.
Good Luck
C2S
Sep 14, 2009 | Logitech Cordless Mouse
USb mouse on my ACER aspire 5100 freezes
USB is short and not working in the laptop , Hire a tech to take care of this for you.
Feb 01, 2009 | Acer Aspire 5100-5033 Notebook
Logitech LX5 mouse
check the batteries. reset the control panel/mouse properties and ensure you have latest drivers.
Jun 21, 2008 | Computers & Internet
Logitech mouse
check the cable of your mouse,maybe its loose connection..try to reconnect it( usually, the cable end is color green) OR if it is in USB drive, reconnect it to the USB port then restart your computer. That's it!!!
Feb 07, 2008 | Logitech Wheel Mouse Optical
My mouse freezes up
have you tried new batteries?
Sep 15, 2007 | Dell U0636 Mouse
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
