Hi Marilyn - As military time is the same as 24 hour time, did you mean you'd prefer to display 12 hour time rather than 24 hour time?
The phone's manual explains how to alter the clock format so I've copied the relevant part for you.
DISPLAY SETTINGS (page123 of manual)
EASY SET-UP
To set up display options using the Easy Set-up Wizard:
1. Press the Center Select Key [MENU], select Settings & Tools and press the Center Select Key [OK]. Select Display Settings, press the Center Select Key [OK], select Easy Set-upthen press the Center Select Key [OK].
2. Select the display settings including the PERSONAL BANNER, DISPLAY BACKLIGHT, KEYPAD BACKLIGHT, MAIN WALLPAPER, DISPLAY THEMES, MENU LAYOUT, DIAL FONTS, MAIN CLOCK FORMAT, FRONT CLOCK FORMAT, and press the Center Select Key [SET].
To skip the step, press the Right Soft Key D [Skip].
MANUAL FOR CASIO RAVINE
http://nec-casio-mobile.com/support/download/GzOneRavine2_Manual.pdf
VERIZON FORUM TOPIC - CASIO RAVINE CLOCK
Casio zOne Ravine 2 Support
