I have pixma ip3600 canon printer, been used 8months working fine, but today, when I turn on just wait for little whileand the amber light turn on, and when I open thetop cover the printer head won't move at all, please show me how to fix the problem. thanks. Email ( [email protected] )
Switch off the printer.Please disconnect the printer from the computer.
Clean the printer inside with compressed air if you can otherwise open the printer cover and see there is no dirt/grit/paper stuck up.
Replace the cove and the reconnect to the computer and switch it on.
If it still shows the error then I am afraid you have to show it to a technician as some component has been displaced when it was moved.
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer. To reset follow this: 1. Turn off the printer. 2. Pressed simultaneously for 10 seconds on the following buttons: 3. Release the button "On / Off". 4. After a few seconds release the other buttons.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred
when the motor was running during the purging operation on start
up.Check the sheet feeder and purge unit.Sometimes pieces of paper
stuck in purge unit.
Put the colors out of the printer and do it on and off a few times and put the colors back in and a few times on and off again, that was working on my 6a80 problem.
