Try if the Bose system have some setting need to be adjust or if your machine is configure properly on the audio section.Is a little bit hard to explain since is a step by step operation but check this two.Audio section on your ps3 and audio setting on BOSE System.Usually if the Bose Allow Direct setting use it.I had the same problem with a Onkyo receiver.Technology suppose to make your life easy but sometimes is complicate to understand.
Thanks for advice. Should have mentioned that the audio did work for several months then suddenly dropped out. fkathome
