Question about Bernina 1008
Had my aurora 3 days sewed on it today.. just straight stitching i hear a ping then the screen starts to flash then its smoking...why??
    New Friend:
How much did this cost? I have the same problem..
Posted on Nov 02, 2015
Call the dealer who sold it to you. It is a barbequed board. That's what your warranty covers.
Posted on Aug 09, 2008
I have a new elna 860 expressive today when I switched it on only some of the icons are lit up, the straight stitch and tea shirt icons. On the straight stitch setting only the top 4 icons are lit
Is it "brand new," ie just purchased from an Elna dealer? If so, take it back immediately! It is still covered under warranty.
Possibly some of the computer components are failing. This, most often, requires professional service.
Jun 14, 2016 | Elna Sewing Machines
My 9000 screen is not working properly. Everything shows up but when I touch a stitch it won't change, can't adjust, the up/down button, back stitch buttons don't work either. What could be the prob
Hi, It probably is not major. Computerized machines have circuits that can be replaced. Take it in for service and then you will have your "go" machine in tip top shape.
Feb 04, 2014 | Janome Memory Craft 9000 Computerized...
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Kenmore 100 stitch machine will not form stitches
it's probably time for the machine to be serviced
May 29, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Singer Model 6212c only sews in reverse... Just brought this machine home today. Ha Ha, it only sews in reverse mode.
there's probably nothing wrong with your machine.
check and see if your stitch length setting is set to Stretch instead of somewhere between 2 and 3.
If it's in the stretch zone (below 0), it can sometimes sew backwards unexpectedly depending on what stitch you have selected.
make sure you have selected a straight stitch, and then select the highest stitch width and a stitch length of somewhere between 2 and 3.
it will most likely work fine.
Apr 02, 2010 | Sewing Machines
Aurora 430 Bernina
Hi, possibly your feedogs are dropped and in the darning position and/or its thinking you want to embroider and there is NO hoop attached or entire embroidery unit plugged in. Check your feedog button below the handwheel on the bottom.
Rick
Jul 29, 2009 | Bernina Sewing Machines
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
106 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
