Question about Refrigerators
Is it safe to position a Mini Freezer on top of my fridge? The mini freezer is 25kg. I'm v constained by space in my kitchen and this would be the best place for it.
    President:
  • 1,462 Answers
Should't be a problem but make sure both have plenty of ventilation
Posted on Jun 21, 2008
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
My mini fridge is a big freezer.
It is the temperature sensor. It is normally attached to the evaporator itself (the freezer part that gets cold).
Jan 06, 2010 | Kenmore Refrigerators
Refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
Oct 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
