Question about HP 48gx Calculator
Switch on AND switch OFF
My HP-48G in swichint On only when I simulteneously press and release ON and F buttons , and does not switch OFF as written in the manual. It works fine once swiched ON . Is there any service center in INDIA?
S K GOSAVI ,BARODA, GUJARAT, INDIA.
  • HP Master
  • 7,993 Answers
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
You can also try this site. They do repairs on most models, except the newer ones.
Posted on Nov 09, 2009
I shut off TV with remote and now it won't turn on
switch on your gadget then if it has a red light , its on standby mode, try to press p- and p+ buttons simulteneously or p+ alone
Sep 08, 2017 | Televison & Video
Firmware update for 3Com 2952
Don't let the switch name fool you, HP calls it the HP 1910.
HP 1910 48G Switch Fixed Port Web Managed Ethernet Switches HP JE009A ABA
Technical Notes:
"The HP 1910-48G Switch (JE009A) was formerly sold as the 3Com Baseline Plus 2952 (3CRBSG5293) and may ship with this product labeling.SFP ports and copper ports work simultaneously, independent of each other to give a total of 52 Gigabit-capable ports."
Firmware download from HP:
My Networking HP Official Site
Jan 14, 2013 | 3Com Baseline Plus 2952 52 Port Gigabit...
Dark blue screen can't see display.
With the calculator on, hold the ON button and press the - button to lighten the display. If you go too far, use ON and + to darken the screen.
Aug 28, 2011 | HP 48G Graphic Calculator
My HP 48G does not come on.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
Hope it helps and Thank you for using FixYa.
Do not forget to rate the solution.
Nov 29, 2009 | HP 48gx Calculator
I just changed the battery in my HP 48GX that I haven't used in some time, but the alert symbol is on and nothing else is happening
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 07, 2009 | HP 48gx Calculator
Calc. asks to recover memory, display goes blank, keys beep
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 30, 2009 | HP LaserJet P2015dn Printer
I HAVE A HP-48GX THAT WANT TURN ON.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Feb 05, 2009 | HP 48gx Calculator
HP 48GX problem
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 03, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
HP 48gx Calculator Logo
185 people viewed this question
Ben Johnson
