HP photosmart c5280 PRINTER
Can not load software.Fatal error when loading software
  • jay-ross Jul 20, 2008
    Tried to install drivers off the HP cd supplied with the printer. Errror said
    the driver will not work with windows98, What so I so?
Go to web site and do download of software from there hp.com/drivers/sfotware--put in model number. especially true if using Vista. also ensure your setup when asked is for windows XP and not windows 98/2000
Posted on Jun 21, 2008
When i try to scan a picture, the hp software opens but then a error box come up saying "an error occurred communicating with the scanning device. Please ensure the scanning device is connected properly...
Try turning the printer off for 60 secounds and see if the reboot will solve the problem. Do make sure all cables are connected properly so your computer will be able to load the correct drivers at start up of the printer.
Feb 11, 2010 | HP Photosmart C5280 InkJet Printer
Red exclaimation mark on C5280
Try first unplugging power cable, and see if it clears the error
Jul 29, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
Windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Jan 08, 2009 | HP OfficeJet 6310 All-in-One Printer...
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Photosmart 3310 All-In-One - Cannot install..... Downloaded software from HP web site - 96% install it brings up a "FATAL ERROR" message and then uninstalls it. Running Vista - Help
Hi
The installation will get stalled at 96% , because due to 3rd party service running, will not allow to install HP printer driver.To resolved this follow below steps
1.Disconnect the Printer and uninstall the software.
2.Reboot the PC.
3.Click start, then in "start search" box type "msconfig"(without quotes).Click OK.
4.In System Configuration Utility, Under GENERAL tab, click on SELECTIVE STARTUP, Uncheck "Load System Services" and "Load Startup Items".Click on Apply
5.Then Click on SERVICES tab, at the bottom Check "Hide all Microsoft Services" and then click "Disable all".
6.Click apply and OK. Reboot the PC.
7.Now install the software.
Please let me know once you have done this.
Thanks
Rizwan
Dec 09, 2008 | HP Photosmart 3310 Printer
HP PHOTOSMART ALL-IN-ONE C5280 FATAL ERROR DURING INSTALATION /ERROR SITUATION CODE 10004232 SAYS ERROR ACCURED IN THE SCRIPT PAGE
Make sure that all the software and driver is already uninstalled then download and install the software and driver found on the link below. If it fails to uninstall completely you may need to run a registry cleaner or perform a system restore.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ph&lang=en&product=3204464&
Oct 14, 2008 | HP Office Equipment & Supplies
1.loaded software which came with my photosmart C5280,but icon does not appear on PC screen and I can't access my manual. I have uninstalled software a few times and re-loaded, but same outcome. USB...
fredwilliam- this unit comes with the photosmart essentials software and according to hp this is a low end photosmart... the software might not be getting installed correctly due to insufficient previlages on the computer for your userlogin. Download and run the software three times from the following link from hp http://tinyurl.com/5u2pg then uninstall and install again. If you have had another hp camera or printer installation remove that before you reinstall.
I hope this helps!!
Oct 10, 2008 | HP Office Equipment & Supplies
246 people viewed this question
jasbo
jasbo
