37" LG 1080p
On some stations the picture and sound are breaking up - like a mosaic. It seems to be mostly on the broadcast channels (ABC, NBC, etc.), not the cable channels.
    Scholar:
  • 78 Answers
Hi ks0412,
If you are receiving a High-Definition (HDTV) signal through an over-the-air broadcast, you may see this kind of mosaic-like breakup of the picture and sound if the signal is weak or interrupted. This is the same way that you would receive snow and static with an analog signal in the past. I would suggest readjusting your antenna for better reception on the channels that are giving you trouble.
If you are receiving this broken signal from a subscription-based service such as cable or satellite, I would recommend contacting your service provider for assistance. It could be a problem with the signal, your equipment, or the equipment setup.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 23, 2008
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
Do I need a digtal converter box to pick up local stations via antenna?
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Dec 29, 2010 | GE 31GT720 31" TV
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
We have a vizio vo370m, and instead of being on 1080 the setting is on 720. how do i fix that
What is the source of the signal? If the signal is from ABC, Fox, or ESPNHD, the broadcast is is 720p. Similarly, many older dvd players only provide 720 resolution (those that do not have the up-conversion to 1080 feature).The choice of cables may matter.
So if you are watching HD cable or satellite or OTA Digital TV, try a different channel.
CBS, NBC, PBS and DiscoveryHD provide 1080i. However, not all stations with these networks broadcast in 1080i OTA. (There will only be one sub-channel with the 1080 signal if your local affiliate broadcasts in that resolution.) An XBox will also give 1080i.
Blue-ray players and the Play Station 3 provide 1080p signal to a TV that can handle the signal.
If your source is a computer. what OS and video card is providing the signal? The resolution available will depend on what your computer can provide. Check the specs for the computer. This is more of an issue for older video cards and low end older computers with on-board video. The computer will only give a 1080 output in the 1920x1080 mode at 60Hz. For Windows, you can reset this either with the video card software or by right clicking on the desktop (anywhere without an icon or running program). Restart the computer to get the mode to synch in some situations.
I hope this helps.
Nov 25, 2010 | Vizio VO370M LCD TV
Lost sound on ABC,NBC,CBS & ESPN classic
on your remote there should be an MTS button, try that because sometimes they broadcast shows in/on mono,stereo or sap. go to those channels and try switching to either mono,stereo or sap. let me know and good luck
Jun 16, 2009 | Emerson Televison & Video
Can't get digital converter box to work with Toshiba TV/VCR Combo
You will need to rescan your stations. On the June cutoff date, they reshuffled and renumbered most of the stations.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
I have a one-year old 37LG50 TV with a direct line (no box) to cable. How do I 'label' (using the remote) the various channels with their names (i.e., NBC, CNN, ABC, ESPN, etc) so that when a channel is...
Assigning a station name
Select SETUP.
Select Manual Tuning.
Select TV.
Select Name.
5
Select the position and make
your choice of the second character,
and so on.
You can use an the alphabet A
to Z, the number 0 to 9, +/ -,
and blank.
6
Select Close.
7
Select Store.
Jun 07, 2009 | LG 22LH20 LCD TV
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
Sound problems with Insignia Flat Screen 37
It may be that the set is set for alt sound. go to the menu and set the audio to stereo. If the audio is set wrong it thinks you are set for spanish and if the broadcast is not in an alt language there will be no sound.
Jul 10, 2008 | Televison & Video
Don't get ABC or NBC local channels anymore
ATSC tuners ("D/A converters") pick up signals off the air just like old school television. It sounds like you are just not getting a signal of sufficient strength. A weak analog signal looks like a "snowy" picture, which most of us are used to. But, the new digital channels quickly go from a perfect picture to none at all. It's basically all-or-nothing.
Try attaching an antenna to your converter. I know you can buy a new antenna from your local big box electronics store which is labeled "Terrestrial HDTV" or something, but that really doesn't mean anything. You can use any old TV antenna. Even a quality FM antenna (with an F-Pin coax connection) may work just fine.
When setting up the antenna, keep in mind that different channels are transmitted from different towers, in different locations with different strengths. Move the antenna placement and position around (just like grandpa had to do). You may have to make a compromise to get the best signal for your favorite channels.
May 15, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
Electro Med Services...
