Question about Sunbeam Grill Series 540
I am replacing the burner assembly on a Sunbeam 540 grill. Have the part, now where do the two shields go? I need a diagram. The larger of the two shields has the number 11230169 stamped on it. It also has a screw hole but I cannot figure out where it goes. I think it goes underneath the bottom and somehow over the gas ports. Help!
    Top Expert:
  • Sunbeam Master
  • 51,187 Answers
Usually those shields go over the top of the burner to prevent food from plugging the holes .
Posted on Nov 03, 2017
3 Suggested Answers
  • 26 Answers
SOURCE: need new burner
www.grillstuff.com please rate me if this was any help..good luck!!
Posted on Jul 21, 2009
  • 30 Answers
SOURCE: We have a sunbeam 540
If the leak is in the black fitting you turn to tighten it onto the tank, that is a replaceable part.
It is part# 86495 from Music City Metals.
You can get it for $13.99+ at marbeck.com
Posted on Mar 10, 2010
Our food doesn't seem to be cooking properly.....it is taking a long time, and seems to kind of "simmer", rather than grill, even though the burners are both on and turned full on.
If this is a propane (LP) grill, try replacing the regulator and hose that goes to the tank. It sounds like the grill is not getting enough gas.
Jul 19, 2011 | Sunbeam Grill Series 540
Can I still get a replacement burner assembly and venturi for a sunbeam 350?
Yes. From Modern Home Products it is part# SBT21. From Music City Metals it is part# 15902.
Nov 10, 2009 | Sunbeam Grill Series 350
I am about to buy a Sunbeam WG541HPB9 grill secondhand and need advice about whether it comes apart from the stand in order to fit it in my car.
most gas grills do cant speack specifically for this one but i dont think i have ever seen one that doesnt come apart
Oct 30, 2009 | Sunbeam Grill Series 540
Need new burner. model number for sunbeam 540 grill
Jul 06, 2009 | Sunbeam Grill Series 540
Need replacement drip cover that is over the burner
we have these in our store, they are not difficult to get.
Jun 09, 2009 | Sunbeam Grill Series 550
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
We have a sunbeam 540 gas grill with a leak in the connector between the gas tank and the hoses leading to the grill. How can we fix the leak?
Jul 05, 2008 | Thermos Stainless Steel Gas Grill
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Venturi tubes
The venturi tubes should go over the gas orifice. If the tubes were to drop off, you could have a fire outside of your grill and possibly an explosion.
Jul 03, 2008 | Sunbeam SG6622RP Grill
Grilling Logo
222 people viewed this question
Top Sunbeam Grilling Experts
Gil Shultz
David White
Steve Pack
Steve Pack
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
