Question about Nikon Coolpix 5700 Digital Camera
Pop-up flash I cannot get the pop-up flash to stow. I am almost positive it is simply a setting that I need to change.
  • 797 Answers
Go to the menu RESET ALL may work. Then go back to the menu and set the settings to the way you want them, test the camera and see if the flash works.
Make sure that the flash settings are on and not turned off in the menu settings.
If the flash is on in the settings and it still does not work, then this camera needs repairs.
Posted on Sep 24, 2008
I just purchased a 2005 cadilllac srx v8 n i cannot get the third row seat tto function? Help?
Rear Seat Switches
There are three push button switches that are used to operate the power folding seat; front stow switch, rear stow switch, and recline switch. The front stow switch is located in the right rear quarter trim panel just behind the second row seat. The rear stow and recline switches are located in the right rear trim panel just inside the liftgate. Battery positive voltage is supplied at all times to all three switches from the FFS SW Fuse located in the left rear fuse block. The folding seat will operate only in a supervised mode, i.e. press and hold the selected switch button through the entire cycle of operation, or release the switch when the desired seat position is reached. When any folding seat switch is pressed, it sends a 12 volt signal through the switch signal circuit to the RSM. The RSM then commands the appropriate seat motors to move in response to the switch signal.
Rear Seat Module and Power and Ground
The rear seat module controls the position of the third row seat. When commanded it moves the seat from the seated position to the stowed position, or, from the stowed position to the seated position. With the seat in the seated position, the RSM can also move the angle of the seat back forward or rearward.
Battery positive voltage is supplied at all times to the module through the battery positive voltage circuit and the FFSM fuse located in the left rear fuse block. This voltage is used to power up the RSM and also to apply power to the seat motors when commanded. The RSM is grounded through the module ground circuit and G401.
The first place to start would be check the fuse's .Do you know where the left rear fuse block is located ? Fuse Block - Left Rear
In the passenger compartment, near the left side of the rear seat under the carpet
If the fuse is good next thing to do would be ,have check for DTC'S in the rear seat module ! This has nothing to do with check engine light or OBD 2 diagnostic trouble codes an a code reader for said OBD2 codes will not work . Would need a factory scan tool to check these codes.
DTC B1395
Battery positive voltage is supplied at all times to the rear seat load floor switch and the rear seat position switch by the rear seat module (RSM). The RSM monitors these battery positive voltage supply circuits for the protection of internal circuitry of the module.
DTC B1395 Device Voltage Reference Output 1 Circuit
DTC B1420 Device Voltage
Battery positive voltage is supplied at all times to the seat adjuster switch and the memory seat module (MSM) through the same circuit. The MSM uses this battery voltage input to determine if battery positive voltage is applied to the seat adjuster switch.
DTC B1545 Seat Stow Switch 1 Circuit
DTC B1546, Seat Stow Switch 2 Circuit
DTC B3729 Seat Recline Control Switch
DTC B1735 Seat Front Up Switch Circuit
DTC B1740 Seat Front Down Switch Circuit
DTC B1745 Seat Rear Up Switch Circuit
DTC B1750 Seat Rear Down Switch Circuit
DTC B1755 Seat Assembly Horizontal Forward Switch Circuit
DTC B1760 Seat Assembly Horizontal Rearward Switch Circuit
DTC B1815 Seat Recline Forward Switch Circuit
DTC B1820 Seat Recline Rearward Switch Circuit
Just from looking at the factory service info , I'd say you would be bet off just taking this to the dealer !
The first plase
May 28, 2016 | 2005 Cadillac SRX
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
2nd Row Headrest Stuck in Upright Position and will not Fold for Stow n Go
You will need to take the seat apart to determine what is not fastened to release it.
Apr 09, 2014 | 2011 Chrysler Town and Country
Wiper intermittent operation/automatic stowing does not work.
Hey Anon,
I just finished replacing the intermittent (wiper motor pulse board) control on my vehicle.. it was doing exactly as you describe.. it wasn't hard.. just time consuming..
Jun 16, 2017 | 1992 Dodge Stealth
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
Cant set wrist watch
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
How to remove write protect on my usb flash drive
If you have a write-protected flash drive that you need to access, it can be difficult to change it to allow you access, especially if it is a security-optimized flash drive. However, there are a few practical steps you can take to change the write-protection on a flash drive.
#1
Check for a write-protection switch. This switch, when engaged, will lock the contents of the flash drive and is a very common security feature. It is generally located on the side of the flash drive, and has an "enabled" or "on" position, and an "off" position. Slide this into the "off" position.
#2
Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not work.
#3
Format the flash drive. If nothing else works, you can always format your USB flash drive, which will set all your write protections back to default. From there, you can customize them however you want, but all your data will be lost. To format the flash drive, go to the My Computer, right-click your drive and select "Format." A status bar will pop up. Once the status bar disappears, you can change the write-protection settings on your flash drive without incident.
Hope this might help
Thanks
Oct 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windshield wipers work fine on all speeds. When they are turned off they stop in the "open" position not the normally stowed position.
Don't know which Make or Model your vehicle is, but it sounds like it needs a "Factory reset" on your wipers.
Check your User Manual - there is often a set of instructions on how to reset things like "Central locking"; Auto Window closing"; Wiper settings & things like that.
Usually these type of problems occur if the car battery has been disconnected or exchanged.
If this is the case, the management system needs resetting to your prefered options.
Nov 17, 2009 | 1998 Oldsmobile Silhouette
Auto flash won't pop up
With the Canon XSi, the flash should automatically pop up in FULL AUTO mode when it thinks it needs to. In modes like Manual Mode, you need to pop it up yourself. There is a button on the front next to the lens that looks like a lightning bolt, that's the flash activator. Try popping your camera into Manual Mode and press that button. If it doesn't work then there might be a problem with the mechanism and needs repairs.
May 24, 2009 | Canon EOS Rebel XSi Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
88 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
