Question about GE DPGT750GC Gas Dryer
No heat blower motor no working
If the blower motor is not working...is there a way to test it.i really dont want to be replacing parts and not fixing it.....
frustrated
The only sure way is to connect a good motor and see if it runs. In the last year I have replaced a few of those motors and no control boards. All the tests are electrical and the normal failure for that motor is mechanical.
Posted on Jun 21, 2008
Blower not working
To determine the cause of a blower fan failure, isolate the motor, and perform some basic electrical tests.Check fuses first. Fuse failure often causes component failure. Check for power at the motor itself. Test the connection to the blower motor. Test the switch.-------------------------------------------------------------------
Car Diagnostic Tools
Dec 01, 2012 | Cars & Trucks
Heat and air Condition dont blow
The heat or air do not blow, this would mean the blower motor is not working, the first step would be to check the blower resistor as this is a common problem on these.The best way to test this would be with a test light.Take the test light and turn heat on then check blower connector for power, note unplug connector and test, make note of which wire has power, then connect the plug back. using a piece of wire connect one end to a good ground and stick the other end into connector on the blower that had no power and see if blower runs. If the blower runs then you have a bad blower motor resistor, this is located next to the blower on heater box, if you follow the wires from the blower it will lead you to resistor, unplug resistor and check for burnt connector. if connector is damaged then you will need to replace the connector also, then remove screws holding the resistor in heater box and remove it.
Back to testing if you do not have power on one wire at the blower then check all the fuses, Next if you have power and the ground does not turn blower on then try tapping on the blower motor to see if it turns on, in either case if there is power and a good ground to blower then blower will need replacing. Hope this is helpful good day.
Apr 26, 2012 | 2000 Chrysler Concorde
I have a 93 Jeep Cherokee. The blower motor for A/C / heat has stopped working and I was told it could be either a relay or a blower motor resistor. How do I determine which part I would need ?
You will have to test those parts to see which one is bad......either that or replace both parts, one at a time, and hope you get the right on, on the first try. Also, when the blower resistor goes bad, it usually still works on the highest speed but not any others.
BTW, has anyone tested the actual fan blower motor, to see if IT might be bad?
Sep 13, 2011 | 1993 Jeep Cherokee Country
Motor blower not working
IF FUSE IS GOOD TEST LIGHT WILL LIGHT UP ON BOTH SIDES.IF IT LIGHTS UP ON ONE SIDE.IT BLOWN.REPLACE IT.ALSO CHECK TO MAKE SURE BLOWER MOTOR GROUND WIRE NOT BROKEN OR LOOSE.CHECK TO SEE IF POWER GOING TO SWITCH.IF YES.ITS THE SWITCH IT SELF.IF FUSE IS GOOD AND RELAY.
Aug 02, 2009 | 2000 Pontiac Sunfire
Mercury Mystique 1996 Blower A/C - Heat switch issue
https://s9.postimg.org/9kxjrm85r/mystic_blower_resistor.jpg
Click on the link for part of wiring diagram for your blower motor. The speed control is on ground side of blower motor. At the moment, I suspect a resistor problem. Replace resistor pack or do some testing, to verify.
Mar 31, 2017 | 1996 Mercury Mystique
2002 Nissan Pathfinder-heat works fine but loud screeching noise
You can Check those with a Voltometer But, Ultimately you will have to Change the Blower Motor.
Jan 21, 2009 | 2002 Nissan Pathfinder
Heater is dead
My 2000 century heater blower died,dont replace the fan motor until you check with a simple test light to see if the heater fan resistor is bad first,it's only 20 bucks to replace.Its located next to the fan housing up against the firewall.The wires from the fan switch go down to the resistor, check to see if switch has power then check for power down at the resistor,I'll bet its the resistor.There are three, I think five sixteenth screws to remove the resistor one is crammed up very tight on the firewall,you'll need a quarter inch drive extension with a wobbly socket to get that one against the firewall.
Dec 13, 2008 | 2000 Buick Century
Heat levels..
need new technician.if the blower motor works even with only one speed than the blower motor works and did not need replacement.sounds like blower motor resistor or resistor wiring,when there is a problem with the resistor or wiring you will only have one speed,this way you atleast have heat.so if your tech replaced the blower motor when it worked and did not need replacement then it sounds like he is just throwing parts at it,you have to wonder if he really checked anything.have the resistor and wiring checked and if ok then check the heater control head and wiring.
Nov 06, 2008 | 2001 Ford Expedition
Open Questions:
Dryer is acting up. so, it hasnt been used in about 2 months.  it sat out in a cold garage.  but was back up to 'room temp' when we hooked it up.  the gas line is secure.  the venting is proper.  the dryer's level.   after turning it on, not much has happened.  a faint 'beeping' signal comes out of it every few seconds or so, and signal lasts about 2 secs.  the dryer will tumble and kinda gets a weak luke-warm.  i heard this clicking (blower motor i think) as if it were a rotating clicking noise.  then i heard what sounded like a piece of plastic drop.  then poof! the blower kicked on and the dryer started crankin'! working great.  thought maybe something needed to settle.   note* i did have this dryer on its side while moving it in the back of my pick-up truck.  (which was covered from the elements w/ a cap & laid on soft blankets).* after several uses some serious noises started coming out of it.  a severe clicking rotating plastic thumping, sounded like hard plastics banging, clicking rotating, hard to explain.. i reset the dryer.  now it starts up, and just rotates, blower never kicks on.  doesnt really get hot, back to a weak luke-warm.  (i threw a wet towel in there..nothing, no heat/blower)  nothing going through the vent either.  so..i was thinking about pulling the back off, but figured i'd ask you guys first. also, do you think it's worth it to call in a Sears professional?  costs involved?   yeah man, any help would be appreciated, the thing's out of warranty, and well..i need a working dryer, full household.  laundry piles up!   - thx, Angelo
Feb 28, 2017 | GE DPGT750GC Gas Dryer
GE DPGT750GC Gas Dryer Logo
78 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
