Question about Dryers
Whirlpool electric dryer
Heat selection dial does not move during operation, and no heat........dryer will run and run and run ....................
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a generic answer that may assist you in gaining a diagnosis. Fix the NO HEAT symptom and your other complaints should be resolved also.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward
Posted on Jun 21, 2008
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
I have a whirlpool dryer and for some reason it has quit getting hot so it's not drying my clothes. Also my dial wont turn. When I turn the dial to start a load it never moves from the begining...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 24, 2011 | Whirlpool Dryers
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
I have a whirlpool dryer that doesn't heat up and it will not stop running and the dial doesn't seem to move
Hi, The timer will not move if there's no heat when you have it set on the automatic cycle. I need to know if this is electric or gas. Please get me a make/maodel 3 so I can help you through this.
Thanks
Vic
Jul 18, 2009 | Dryers
Dryer does not heat
when your dryer does not heat the timer will not advance, check the heating element and the thermal cut out kit
Jun 25, 2009 | Whirlpool LER4634J Electric Dryer
My dryer operates well but cuts off during operation.
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
