Question about Palm TX Handheld
On Palm TX Hotsync Manager will not open
My TX crashed yesterday. I went to Hotsync and it took an unusually long time and whe I went to my palm it was newly configed and I lost most calander to back Oct 07. I did some moving around on my applications on the Palm then synced a couple of more times and it the changes I made on the palm were not updated. Went to tech and I was told to hard set. I tried a few times with holding power button down and soft booting. To no aval. A while back I had lost my regular power button so I had one beamed to me by my Doctor who had the same palm tx and power problem I had. I set my power botton on the right front button and had no problems.
So I went to application and opened power button and it had the hard set option. So I did.
Tried to Hot Sync no luck. Went and downloaded a a hotsync program. came up with error 273HotsyncWizard.exe. Tried to sync again no luck. Went to devices and USB port came up Unknown. Troubleshot that no luck., changed ports and things went crazy beeping and blinking. Can't hard set because the powerbutton was deleted - should have copied to disk before.
Now Hotsync Mangaer will not open,checked properties and got the right setttings had to go to Windows 2000 yet I have XP.Now when I plug the USB in the computer beeps and devices blinks. Cleaned contacts no luck. Same symtoms
PLEASE anyone..have a solution short of buying anonter tx..this TX is my second brain. Have back up dating back to 2003....
Obliged, Paul
I
    Genius:
  • 1,036 Answers
Hi there!
Have a look here on Diagnosing program issues
Hope this helps, or puts you on the path to a solution.
Thanks.
Posted on Jun 21, 2008
    Master:
  • 848 Answers
Check whether the power supply is proper
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
My computer that I sync my Palm TX to was "wiped" clean. What steps would I need to take to be able to resync my Palm TX to the computer and not loose everything I have stored on my Palm TX?
Palm Desktop and HotSync won't destroy the data on your device if you have a fresh copy that doesn't have your data backed up. That said, however, look for free utilities that will back up your TX's data to an SD card should HotSync wipe your TX as well.
Jul 09, 2010 | Palm TX Handheld
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Feb 12, 2010 | Palm TX Handheld
Purchased a used Palmlllxe and need the start up cd and owners manual
Here you go.
http://kb.palm.com/wps/portal/kb/common/article/47831_en.html#palm3xe
This has links to manuals and software. To get started you need the Palm Desktop, which allows you to backup and restore most of your data. This also provides the Hotsync Manager utility, whcih you can use for installing applications and syncing.
for baba here is the link for Tx
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html
Mar 14, 2009 | Palm TX Handheld
Can't sync palm tx with new vista based desktop
Sir,
Try to hard reset or check whether the computer is updated OS and also check this link for "How to hard reset"
thanks
good luck
Dec 15, 2008 | Palm TX Handheld
Palm Tx problem after hotsync
I had the same issue, the palm is stuck in a loop,
I got mine out of this by pressing the power button while the palm was on the screen where the bar goes across the bottom, it asked me if I wanted to erase all data, I said yes, and it reboot normally, I went thru the setup, and all is o.k.
I did have to try this several times, but it eventually worked. Hope this helps, although it looks like this is an older question. I hope you have resolved it.
Oct 12, 2008 | Palm TX Handheld
Crash after Hotsync
There were some problems with the hotsync working with Vista. I don't know if they fixed them yet. Best bet is to look on Palm.com and see if the current hotsync program supports Vista.
If it isn't listed, it may not support it.
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
Handheld Calendar Does Not Sync
Is KsDatebook compatible with Palm? Palm suggests only two programs to sync calender files with Microsoft Outlook and the one that comes with the TX CD.
Jun 04, 2008 | Palm TX Handheld
Palm TX Handheld Logo
180 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
