Refilling original TO711 epson cartridge - Computers & Internet
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    And your question is?
Go to http://www.pioneerthinking.com/mp_refillink.html  the solution and tips are clearly explained.
Posted on Mar 02, 2009
Definitely, your question is?????? if you wnt to do a refill function go to inksell, inkstop or local vendor and see what can be helpful to you....
Posted on Jun 21, 2008
I just bought all new Epson cartridges and now my printers says "It doesn't recognize the cartridges
take them back to the place you bought them,if they are original epson cartridges,they should work,not if they are refilled though
Jul 11, 2015 | Epson Stylus Office Equipment & Supplies
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Why is my wf-4630 not recognizing initial cartridges?
if they are not epson original cartridges,they wont work,you cant refill or by refilled cartridges to use in this printer,if buying used cartridges,you have to be able to reset the printer,some cartridges reset the printer but most dont
Aug 07, 2014 | Epson Office Equipment & Supplies
I have bought an ink cartridge other than epson and the printer is telling me i must use epson ink. Can i over ride the printer?
No actually you cant. Epson has included special firmware with the machines in order to prevent this. Basically the printer will no print without original products. So even if you refill the cartridge it still wont work. Epson Claims this is to prevent damages to the machine, so you have to buy the original expensive Epson products.
May 07, 2011 | Office Equipment & Supplies
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson c88 shows ink out in all four cartridges but they are full
Are they "original" Epson ink-cartridges, or have they been refilled? Often, the refilled cartridges will show as "empty", but they work, until they _do_ get empty.
Apr 16, 2010 | Epson Stylus C88 InkJet Photo Printer
Placed 2 refillable cartridge in epsonstylusnx110 not being read
I would first ask if they really are re-fillable.
Take a look at this page and see if any of it applies to you and if you still have issues please give me any additional info you have about the issue so I can investigate further
Bob
Mar 02, 2010 | Epson Stylus D92 InkJet Photo Printer
How do I put a black cartridge TO711 into my Epson printer
well are you can either use the maintenance tab on your computers printer driver to manually move the printer head for you to replace your black ink.
pls take note that epson printers dont work if one ink is out or depleted.
Sep 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
FILLING TO711 INK CARTRIDGE. CANNOT FIND ENTRY TO FILL THE CARTRIDGE
There are two fill holes on the cartridge but you require a machine to refill it as it uses pressurized gas to load the ink.
You can aquire aftermarket cartridges for about half the price but most refilling business do not have the proper machine to fill them.
If you do find a place that can refill them make sure they rest the counter chip on the front as it still reads empty unitl the chip is reset.
Chris
May 05, 2009 | Office Equipment & Supplies
I need to refill my ink for a espon stylus cx4400 printer, don't know where the hole is located at the top to put the ink inside
Epson have designed their cartridges so that refilling is virtually impossible. Believe me a LOT of money has gone into this so I would forget about trying to refill your original cartridges.
Instead I would recommend locating a reseller for refillable cartridges with a resettable chip... Also, be very careful buying any old ink as there are some very cheap, poor quality inks available which are more likely to clog your printhead and drive you crazy. Good brands to consider are Image Specialists, hobbicolors and OCP but there are others out there.
Hope that helps.
Mar 02, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Computers & Internet Logo
786 people viewed this question
David Payne
David Payne
