Samsung I've had my tv for 3 years. I turned it on this morning, it played for an approximate 2 minutes and turned itself off. There are three lights that are flashing (one red, two green). They are: standby/temp, the timer and lamp.
  • 44 Answers
Replace the lamp - they only last about 2 years with 4 hours use per day.
Posted on Jul 03, 2008
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
My tv come on and turns off stays on 3 min.
How old is your tv and when was the lamp changed last? If its more than two years then you need to change the lamp. Its easy DIY. Buy lamp from reliable source or a known shop. check out rate for lamps on www.fixurtvs.com. thanks if you voted.
Apr 12, 2010 | Samsung HC-R5245W 52" HDTV
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
Tv switches off after 5 mins
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
May 09, 2009 | Televison & Video
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Dec 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
287 people viewed this question
Top Televison & Video Experts
Electro Med Services...
