Question about Mintek DTV-263 26 in. LCD Television
Frozen and controls wont work
Only off/on button on TV works no others.Anyway to reset this pig before I use it for target practice?
  • 1 more comment
  • ghogin74 Jun 25, 2008
    I have the same problem and can't get any answers.
  • djviado Jul 03, 2008
    I have the same problem. It is a great television EXCEPT for these problems. I hope someone representing this product will help these "valued customers" before the list gets beyond control.
  • bigg1149 Nov 30, 2008
    my tv is frozen also dvd stuck inside will only turn on and off
    Problem Solver:
  • 14 Answers
Here is the fix for this:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Posted on Nov 04, 2008
I purchased my TV at costco about 1 1/2 years ago and have the exact same problem. I called their concierge service and they told me that the TV is not repairable. They sent a recomendation to the local store manager and they are going to process a full refund.
Posted on Jul 26, 2008
Same problem here!
Posted on Jul 23, 2008
Child lock and the remote wont work on it i tried other tcl remotes and it the same thing the buttons on the tv dont work either when press it says key lock help me out plzz
Can the tv be reset to factory default , if it can this should undo the parental lock.
If not, contact a repairman who has experience of your make. I had a forgotten password on a technomate satellite receiver and the technician told me that the model I had was installed with ageneric code in case the user set code was forgotten.
Anyway, reset if you can and ask a tv technician if you cannot
good luck
Jun 23, 2015 | Televison & Video
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
LCD 32lg3000 frozen
Make a hard reset to this set, and try again. To make it a hard reset, unplug the power cord from wall socket, and re-plug it into after 10 minutes or so. This must make it a hard reset. In most cases, this must help.
Jul 18, 2012 | LG Televison & Video
Viewsonic TV N3735w, frozen on menu. Buttons do not work on TV. Pushing buttons on remote: "registers" on TV for a second but always returns to menu, regardless of button pushed. Cannot...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 25, 2017 | Televison & Video
The TV is frozen on one channel manual buttons not working nor re
hello here is how to reset your tv. turn on the tv while holding the reset button on the remote control,press the power button on the tv (the tv will turn itself off, then back on again) release the reset button. if this don't work get back to me and we'll try some think else good luck
regards
shaun
Jul 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
AKAI Menu screen wont stop flashing over tv signal
May 11, 2017 | Akai PDP42Z5TA 42 in. Plasma Television
LG REMOTE WONT SWITCH FROM AM/FM TO DVD
HI THERE, I FIXED THE PROBLEM MYSELF BY KEEPING THE FUNCTION BUTTON ON THE DVD PLAYER PRESSED UNTIL IT FLASHED ""MODE"". THEN I PRESSED IT IN SEQUENCE TILL IT CAME UP WITH DVD/TV THEN IT AUTOMATICALLY SWITCHED OVER TO THE DVD FUNCTION MODE. ALL DONE. BUT THE TV/DVD BUTTON ON REMOTE STILL ISNT FUNCTIONING OR CROSSING OVER CHANNELL. HAVE TO DO IT MANUALLY VIA DVD PLAYER. EVERYTHING ELSE WORKING EXCELLENT. THANKS ANYWAY. HOPE THIS INFORMATION WILL BE OF USE TO YOU IN THE FUTURE. I CUD CHARGE YOU FOR THIS INFORMATION BUT I WONT THIS TIME.... LOL. MERRY CHRISTMAS AND GUDBYE...
Dec 13, 2008 | LG Televison & Video
Phone glich
taylorc-88 - you need to have the flexcable replaced on the phone
Crossinashes - master clear the phone and also reflash the software on the phone.
Apr 07, 2008 | Motorola Mobility RAZR V3
Mintek DTV-263 26 in. LCD Television Logo
154 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
