Computer can't run ,the power is on
My computer is new ,after setup ,I turn on the computer ,the light of the computer is on but the computer does'nt run
    Guru:
  • 1,342 Answers
Make sure that your monitor is connected properly and turned on.
Posted on Jun 21, 2008
Foxconn nt-a3700 does not power up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps
Jun 20, 2012 | Foxconn nt-A3700-0H0WBANA Black Mini /...
Network woes with MA101
Question
What is a "code 2" error
Question
What is a "code 2"
This error occurs when the BIOS did not assign an IRQ to the device. This is most likely to happen on a system that is not PCI compliantand/or is not capable of Bus Mastering. In such a situation a suggested ISA Ethernet Card would be the best sol
Error message "No domain server is available to authenticate user password"
There are any number of reasons this can happen. Please check for the following:
Verify ALL connections to the network are valid (cables, connectors, ports, etc.)
If there is no NT Domain server on the network:
1. Right-click Network Neighborhood, then select Properties from the list.
2. Double click Client for Microsoft Networks.
3. In the new window that appears, uncheck Logon to NT Domain. Click OK on all open windows, and restart the computer when prompted.
If there is an NT Domain server on the network check to make sure that:
1. An IP address has been specified.
2. The computer has been configured for DHCP.
If DHCP is configured and the error message continues to come up, ensure that the DHCP service is running correctly. Contact Microsoft, or your network administrator for assistance with this.
for more clarification log in to http://kbserver.netgear.com/
Dec 09, 2007 | NetGear MA101 802.11b Wireless Adapter
Grounded battery while car was running, suspect the engine comtrol module is fried. Sound right? If so, where's the ECM located on an 89 Wrangler?
It's likly you did alot of damage. First with a well charged and correctly installed battery it's best to cheal some other things first. The large fuses near the battery( fuseable links) need to be checked to see that their connected. Use a test light to test all of them. ( a test light is a tool that has a bulb in the handle of a tllt that lloks like a clear ice pick and has a wire coming out the end oif the handle. on the end of the wire is a clip to connect to ground ( the negative post on the battry) and as you touch the piont to the positive post of the battery ( or anythign powered) the light will light in the handle showing you that the power is getting to there) The test light should be as bright as the connection at the batery was or you have detrcted a poor connection if the light is'nt as bright as the battery was. Going though all the wires coming from the battery ( theirs alot) repair any that are dead. Then go to the fuse box and do the same thing. Use the test light as a blown fuse can (look ) good and be bad. on the tops of the fuses theirs a little bare place on the fuse and just touch the test light and if lights up on both sides it's good .. If it lights on one side it's bad it it does'nt light at all it may not be on. ( key on or lights on or key turned to crank may need to happen for somes fuses to light the test light) If one side of the fuse lights the light the other side sould light too. If all the fuses check good and the jeep cranks but does'nt run you still need to check it just like any no start car. If it does'nt crank fix that first. Once cranking see that it's got spark. ( plug a plug wire and connect it to a spare plug laying on the head and chank the engine to see if theirs spark. With spark them cheak to see if it'll run with added fuel. Remove the air inlet hose on the throttle body slose a little gas it their and put the hose back on and crank it and if it starts you know it'll runn if it was getting fuel. Cheaking for fuel pump operation is next and the fuse from the pump can be on the fire wall on the passenger side. get under the jeep and put your ear against the gas tank and listen as someone turns the key one and if you hear the fuel pump come on you can say the pump works if not you need to find the fuel pump fuse and the realy that turns the pump on as this short to powercan back feed and blw relays and fuses. Most of the time theingtion module can blown on a back feed and the computer can too but the fuse often protects the computer. The computer is the box ( small cerial box size on the firewall on the passenger side) This part has to be programmed to work so a used one is no help as an old computer can'nt be reprogrammed ( to pervent thief) so a new computer has to be bought and programmed to match your car ( this is best left to a professional shop) I've even had other professional shops come to me to do this work cause you only get one chance at it and the other things i just told you about are much more likly to happen then computer failure and if the computer did fail some of these other problems have happened too and they'll need to be found.. iF THE FUSEABLE LINKS HAVE BEEN REPAIRED OR REPLACED IN THE PAST THEY CAN CAUSE THE COMPUTER TO FAIL AS THEY MIGHT NOT BLOW AND BLOW THE COMPUTER INSTAED.
Jul 11, 2011 | 1989 Jeep Wrangler
We just got a 1998 ford escort, automatic with 106,000 mi on it. two weeks passed and the check engine light came on. It was the tps, it was changed n no change. The car turns on after third try, jumps at...
Did you reset the computer because if you don't the computer does'nt reconize the new sensor and it will run as if you did'nt even replace it.You can reset it with a scan tool,or take the ground cable off battery for 30 seconds or pull the ECM fuse then put it back.
May 15, 2011 | 1998 Ford Escort
My 2001 oldsmobile alero hesitates and dies when the ac is on.
There are a number of issues that can cause these problems your having with your Alero. The dealer or local auto repair should check your engine computer for problem codes that can help find and correct this problem. Best of luck.
Apr 19, 2011 | 2001 Oldsmobile Alero
I have a HP Compaq dc5700, and i want to set it to default settings. I do not have any passwords for it. It has windows vista. i tried going to setting(f10) and it asks for a password. I removed the...
Password Security
Establishing a Setup password:
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down >
Restart.
2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter
Computer Setup. Press Enter to bypass the title screen, if necessary. If you do not press F10
when prompted, a restart will be necessary.
3. Select Security > Setup Password and follow the instructions on the screen.
4. Before exiting, click File > Save Changes and Exit.
Restart.
3. Select Security > Power-On Password and follow the instructions on the screen.
Changing a password:
1. Turn on or restart the computer. If you are in Windows, click Start> Shut Down > Restart.
To change the Setup password, go to step 2.
To change the Power-on password, go to step 3.
2. To change the Setup password, as soon as the computer is turned on, press F10 when the
monitor light turns green to enter Computer Setup. Press Enter to bypass the title screen, if
necessary.
3. When the key icon appears, type your current password, a slash (/) or alternate de-limiter
character, your new password, another slash (/) or alternate delimiter character, and your new
password again as shown:
current password/new password/new password.
NOTE: Type the new password carefully since the actual characters do not appear on the
screen.
4. Press ENTER.
The new password will take effect the next time the computer is restarted.
Deleting a password
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down > Restart.
To delete the Setup password, go to step 2.
To delete the Power-On password, go to step 3.
necessary.
3. When the key icon appears, type your current password followed by a slash (/) or alternate
delimiter character as shown. Example: currentpassword/
4. Press Enter.
from
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00794304/c007943
04.pdf
Feb 09, 2010 | Computers & Internet
What is the term ntldr mean, i get this message when trying to install a new hard drive
Computer hard disk drive is not properly setup in BIOS
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Mar 23, 2009 | Computers & Internet
Lego Creator fails run on XP machine.
right click on icon, and select compatibility for nt or xp
Dec 27, 2008 | LEGO interactive LEGO Creator for Windows
Poweredge 2300 Configuration Help Appriciated :)
I have a older poweredge 2300 i get the following message run program setup.
Mar 26, 2008 | Dell PowerEdge 2300 Server
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
