Question about SAMTRON 55V 15" CRT Monitor
MOnitor reddish color
My monitor sometimes changes to reddish colour
Try a new cable; you may have bent or broken pins.
Posted on Jun 23, 2008
The colour depth of my monitor is more yellowish.
is better check your vga cable which attached pc to monitor or change your monitor color on setting
bye
Jul 08, 2009 | Compaq CV 7500 17" CRT Monitor
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Whole display is of reddish colour -Samsung 945NX LCD
try to update the lastest version of your video card driver
May 12, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Appearance on monitor is reddish in appearance
Depending on your monitor settings, you should putt all 3 colors on either 0 or 50. whichever is in the middle of the spectrum in your settings. However, when I've seen this problem on monitors, it's been a problem with the cable. Sometimes the cable is tilted, meaning some of the pins aren't connecting. In other cases, missing or bent pins can cause this too. So try to check out both ends of the video cable and adjust it accordingly.
Aug 10, 2008 | Hyundai L90D+ 19" LCD Monitor
Green color missing from my LG 700s model
as you are electronics engineer so let us discuss technically.
as you are unable to see green colour means you might be seeing picture of magenta colour
as technically
red+blue = magenta
crt has got three cathodes
your two cathodes circuit is fine one ckt that is green cathode circuit is not working.
for that problem your will have to check
  • cable from computer to monitor
  • loose contact in crt base.
  • crt connector loose
  • voltage on green video output.
  • green video output transistor might be defective.or print loose.
  • circuit related to green video ckt
  • green video signal coming to green video ckt.
  • & finally crt defective (in rare case.)
  • hope this will help
  • good luck.
Oct 16, 2007 | LG Studioworks 700S 17" CRT Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Reddishness in the screen
Have you loaded the drivers which came with the monitor. This will probably allow you to change the settings.
Right click on an area of your desktop and choose properties. Look at the monitor and make sure the resolution is set to the recommended level possibily between 60 or 75 dependant on the model. Also you can get to the display card settings here and change them to suit. Dont get carried away or you can make it so that you cant see whats on the screen at all to be able to change it. Could also be that your monitor is faulty. Check with your manufacturer. It its an old telly type monitor maybe one of the "guns" have gone so you dont get the right colour mix of red green and blue. If this is the case you will need to get a new screen.
Oct 15, 2007 | LG Studioworks 563N 15" CRT Monitor
Lcd bad colour
backlight may be going. if color is reddish or pinkish tinge. backlight is part of lcd glass itself, can be repaired, but not many shops repair them. can also buy replacement lcd glass for $100 ro so.
Aug 24, 2007 | NEC MultiSync 1920NX 19" LCD Monitor
SAMTRON 55V 15" CRT Monitor Logo
74 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
