Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
No power My P4M800PRO-M2 VER:2.0 motherboard has no power, fan is not working, but my there is a light on my hard disk led that indicate ther is a power.      Please help me with my problem. Thank you and God Bless.......
  • Anonymous Dec 14, 2008
    to whom it may concern
    i have a problem with my p4m800pro-m v2.0 motherboard, first i incounter a problem that always auto shutdown then i thry to reformat. but when i reach fornmatting into countdown from 39 automatically shutdown i chech the heatsync of processor so hot i found that there is so many dust in the fan thats why the air blow of fan can't penetrate into heatsync. after i finish cleaning of that i statrted again formating but when reach to file loaded (ide files) it hanging up no next. another problem i detach the switch cord from the power switch into the motherboard and i dont know how to get back. any body can show me the manual of the power switch cable going to moterboard? thaks
    marlon
  • 49 Answers
The the 4 pin if near the cpu if connected properly.
Posted on Nov 08, 2011
  • Jay Angel
    Jay Angel Nov 08, 2011
    check the 4 pin supply
  • 144 Answers
Dear Sir,
Try Changing the Power Supply.
Posted on Jun 22, 2008
Intel core 2 Quad Q6600 compatible with ECS P4M800PRO-M2
According to their website, no. The core 2 duo is supported, but not quad core. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=674&CategoryID=1&MenuID=16&LanID=0
Look under the cpu tab.
Oct 31, 2012 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Ecs P4M800PRO-M2 doesn't power up
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Jul 27, 2012 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
I have p4m800Pro-M2. I can not start it. No monitor signal. The fan is working on the cpu. How do i figure out if is the motherboard gone or the cpu, or the video card ?
try removing your ram chips then reinstall them. If your pc still does not start we will work from there just reply back to this posting. I will also need to know if you are using the onboard video or a dedicated video card on the AGP slot.
Feb 08, 2011 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Which vga card compatible wit P4M800PRO-M2, Pci or AGP?
Hi. Thanks for your question.
Video card compatible with your motherboard is an AGP 8x.
Hope this helped. For more info about your motherboard please see this link------>http://www.dealtime.com/Elitegroup-ECS-P4M800PRO-M2-2-0-Via-Socket-775-MicroATX-Motherboard-Audio-VGA-AGP-8x-10-100-Ethernet/prices
Thank you for using FixYa.
Dec 17, 2010 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
How to reset this motherboard? P4M800PRO-M2 (V2.0) from elitegroup.thanks
remove power lead and internal battery for 5 mins then replace all and it will be reset to manufacturer date and settings
Oct 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Algerian-47
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
155 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
