trin to learn how to set my t.v up in digtial format how do you do that .. I am in chicago trin to learn how to set my t.v up in digtial format how do you do that .. I am in chicago
You can't post conmments that contain an email address.
moved you out of cars to TV
no model TV told, at all off rear label.
there are 2 causes (dead picture and dead sound)
PSU dead
PSU overloaded
there are tested for all
check all DC rail voltage to spec.
then if one fails, we disconnect load to this DC pin and see if PSU wakes up. if does the load removed is bad
the service manual cover all this (schematics)
3 choices,
1-sell it. broken( cut losses)
2-buy the service manual and read the tests there and rules for swapping parts not allowed, willynilly.
3-last guess and go broke.
Vizio E Series TV?
5 years old is it or older./
no model stated at all just this, why leave out key fact 1.?
no symptoms, my guess TV is dead, no sound and not smart screens, at all, dead, and LED glowing for standby GLOWing.
that is it ?
first off there is no need to have a TV box at all, zero need.
the TV has smart screen and do stream video off say neflix,
NO TV boxes needed at all just internet.
nor do you need anything at all to use the SMART screen.
it will show all streaming choices at any time, just AC line cord attached and nothing else.
lets to POWER Supplies 101 class now.
1: all Power supplies fail to turn on (even new) IF ANY PART OR MODULE IN THE TV IS SHORTED, (CALLED CURRENT OVERLOADS) THIS ENDS THAT FUNNY FIRE SMOKE THING.
that is JOB 1. not run any TV.
E28 to E75 TV, hummmmmmmmm NO TV even told.
I guess you got ebay bad used cards? PCB cards?
lots are. for sure. used. and if you USA and card not , FAIL !
some TV need hard reset, ever do that, power cord pulled for 1hr.
the hold power button at same time and plug in power cord?
rear power button E32? see that>? works when remote is dead.
but really all this is in the service manual these steps and rules.
TVs are not all the same, ok?> in this regard.
2017 lawsuit to them for spying on customers. TV to them. oops.
avoid them, no?
they do have the cheapest TV made award $159? (this?)_
The E= economy brand, ?
Some are known for dead LED back lamp,power packs or even the LED lamp string dead. known.!!! cheap made parts fail here.
so if screen is dead, and a hard reset fails use the service manual
click page called trouble shooting and click dead screen.
and proceed from there, per the manual first.
the cure is LG, buy LG and win, no kidding.
As you can see TV turns on just like a PC.
the 5vStandy dead,means the logic board can not respond the power on button the power on button is A digital command.
so if standby is dead or noisy,(cap) TV will never ever turn on.
This unlike any TV from 1980 and simple, not it is a computer inside and a OS running to make the smart screen work.(desktop like)
video class:
$10 meter work too, ever word below true, but I can add
lots more can fail there, not just that EEPROM chip. LOTS. https://youtu.be/m_sOrtz2Zy8
moved you to television forum random model not told.
lost the remote
first TV ever?
and batteries died in remote, I am on set 24 batteries in 12 years.
see how batteries sux
all TVs have reset,
ever read the manual first after all no 2 TVs are the same.
so we read the manual
screen is dead but are menus dead.
the rear of all TV s made a label and we read it and the model is there. like my wild guessed one top of this page;.
post you real model or get no answers correct. ever.
if TV is older than 2010 CCFL lamps inside are dead. use flashlight to see that is ture or not.
on my TV the red LED goes out turned on, so you do no have to start at it forever, a huge pain that but must turn out or PSU is dead in TV or the silly batteries in the remote are dead, or weak
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
This tv have a colors wheel.Now ur tv colors wheel it dead.The colors wheel is dead,no colors black&white,loud squiling noises,loud motor noises.All indication of the colors wheel is dead,spinning off of is axis,not function anymore.Hire a tv tech.for this.Not machanically incline,don't atemp to change the colors wheel ur selp.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna. Tune again the channels, and save the preset. If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Sansui SV2118si 54cm colour TV
Very Quick!
