Question about Cross Infoguard Shredder SX102M
Parts available from broken SX102M
Not a problem so much as a potential solution to someone elses problem but I have one of these SX102M shredders that broke a couple of teeth off the large METAL gear in the drivetrain. I knew I'd stand no chance of finding a replacement gear so I've moved onto a new Royal 16CDX (Costco's version of the Royal 160MX) and that means these SX102M parts are up for grabs for anyone who wants to pay the shipping costs to get them.
  • 8 more comments
  • Warren Massey Sep 11, 2008
    Yes I still have the machine. "Plastic wheel" however is a bit too generic a term to tell me which part you mean. I need a better description or a picture. Do you mean the large white plastic gear (covered in brown grease) whose left edge can be seen in the picture I posted? Have you confirmed that the part you need can be separated from the rest of the machine or is it integral to a larger assembly?
  • Warren Massey Sep 13, 2008
    Are you talking about this large plastic gear and its associated pinion shaft?
    If not, try again for a better description or make an effort to include a picture.
    If so, yes I can send you this one if you tell me how to contact you for an address.
  • Anonymous Sep 26, 2008
    i need that big gear that the motor turns
  • Warren Massey Nov 08, 2008
    If you mean this gear, then yes I still have it. It appears to be in good shape. I'll let you have it for the cost of shipping. Let me know how to contact you or where you want it shipped.
  • Warren Massey Jan 07, 2009
    Yes the metal shredder teeth are still available. Let me know how to contact you so I can send them.
  • Warren Massey Jan 21, 2009
    Yes the motor is still available. I'll let you have it for the cost of shipping. Let me know how to contact you or where you want it shipped.
  • cunninghamkd Feb 26, 2009
    i need the large plastic gear near the pinion
  • Arnie B May 11, 2010
    I'm interested in the motor. You can contact me at abilstad@hotmail.com. My address is 335 Pine Street, Deerfield, IL 60015
    I cooked the motor. Is a replacement motor still available?
  • jbop May 11, 2010
    i need the metal shredder teeth. Are they still available?
  • 3 Answers
Do you happen to have any gears left?
Posted on Mar 30, 2010
  • jdrotert Mar 30, 2010
    Do you happen to have any gears for this shredder?
Is this gear still available, if not are the bushings that it goes into still available. if so please contact me at iseicon@aol.com
Posted on Feb 10, 2009
I need the larger plastic gear that is the third drive gear from the motot (partially hidden in the picture above). Please let me know if it is still available. Thanks.
Dan
drearick@juno.com
Posted on Nov 06, 2008
That is the part I need! You can contact me at davecmurph@yahoo.com. My address is 276 Hobcaw Drive Mt. Pleasant SC 29464
Thanks,
Dave Murphy
Posted on Sep 13, 2008
I need the plastic wheel for my sx-102.  Do you still have the machine!
Posted on Sep 10, 2008
  • davecmurph Sep 11, 2008
    Thanks for the reply.  It is the small plastic wheel that runs off of the motor.  It took me 1 minute to remove it.  All I did was remove the three gold colored screws ( you can see them in your picture) on the top and 3 matching on the bottom.  The metal cover came right off and the gears came right out.  I would gladly sent you 20 bucks if you can put it in the mail.
    Thanks,
    Dave Murphy
  • davecmurph Sep 13, 2008
    Yes that is the part I need!  My address is 276 Hobcaw Drive.  Mt. Pleasant SC 29464
    Thanks,
    Dave Murphy
This won't solve it, but we just took ours apart & turned that gear around & it's working -for a while anyway!
doitdel
Posted on Jul 15, 2008
Light dont come on
Shredders have safety switches that turn everything off in emergency conditions. So clean it out good and check movement and function of those switches. Also check for internal fuses, these things can be overworked and blow a fuse.
Mar 08, 2015 | Cross Infoguard Shredder SX102M
Infoguard-10 sx100m motor runs, sounds like gears are turning , goes both forward and reverse. i cleaned all of the teeth, looks clean, but won't accept paper. i am handicapped and am having a hard time...
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck...
Apr 15, 2011 | Cross Infoguard Shredder SX102M
Works in reverse but not forward
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck.
Apr 11, 2011 | Cross Infoguard Shredder SX102M
Infoguard SX 120D Does not power up. No lights
There is a switch on the right side of the shredder itself which has to engage with a tab welded near the top of the basket. Make sure the tab is enagaging the switch. Also check the paper path switch right above the shredder bars.
If you cannot figure this out, please do not pitch the shredder. There a few people here (myself included) that need gears and such from this model. We would gladly pay shipping for such.
Thanks,
John
Feb 03, 2010 | Cross Infoguard Shredder SX102M
Sx 102m reverse works, and auto does not work
Did you try blowing out the sensor with canned air?
No spare parts are available.
Jun 21, 2009 | Cross Infoguard Shredder SX102M
Paper won't feed into shredder
maybe a security feature needs top on to run.
Jun 10, 2009 | Cross Infoguard Shredder SX102M
Broken plastic teeth
I suggest you just go buy a new shredder, otherwise, if you really want to fix it. That would cost you more then you go buy a new shredder.
May 03, 2009 | Fellowes 3011001 Shredder
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
I have a SX102M paper shreder that wont shrede
It's the paper sensing microswitch. Wire a small toggle switch and drill a small hole for it on the far right side of the top housing. Just remember that the switch has to be turned off when you are finished shredding or the motor will keep running till it burns out
Nov 21, 2008 | Cross Infoguard Shredder SX102M
Cross Infoguard Shredder SX102M Logo
528 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
