Question about Samsung LN-T4661F 46 in. LCD HDTV
A HD tv channel pic, the bottom half is good, top half is a lined, fuzzy pic!
Hi. First time ever, I dozed off early morning, woke up and the HD tv I was watching had a good bottom pic but the top half was a diagonally lined bright orange color!
  • YABBY Jun 21, 2008
    So, WHERE IS THE SOLUTION??? I got 2 emails from the GEEK SQUAD stating there was a solution to my problem...I clicked both links and there's NO solution mentioned anywhere!
SOURCE: Purple and white distorted fuzzy lines running up and down and side to side on tv
I just had my lower Y-buffer board swapped out to fix a problem similar to yours. After an hour and a half of on-time, the lower half of the screen would flicker on and off with the same appearance you mentioned. Changing out this particular board fixed it for me. However, since it has gone from top to bottom on your set, it may be more of a main board problem for you (that controls both upper and lower halves). Beyond this, I don't know any more. I am considering getting a service manual to gain more knowledge about the various PCBs in the unit so I can fix any future problems myself.
Posted on Aug 27, 2007
lukster
  • 217 Answers
SOURCE: screnn going blank
sounds like sky tv issue, try different cabling
Posted on Aug 03, 2008
  • 98 Answers
SOURCE: Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Posted on Feb 06, 2009
romsky79
  • 822 Answers
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
Posted on May 29, 2009
  • 257 Answers
SOURCE: samsung lns4051d 40in has horizontal lines across
This sound likes the incoming signal is week. You should play a DVD player to see if the problem stays same or not.
If you try all sources ie HDMI, AV Component, etc...the TV show the same problem. There are two possibilites: T-Con board or main board need replacing. You should need technician to figure out the problem. Hope it help.
Posted on Aug 13, 2009
Testimonial: "Thank you! I'm a do-it yourselfer. Good info!"
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
I have a 40 inch Samsung TV which I've had about 3 years (sorry I Don't have the model number handy). I have DirectTV and an HD-DVR. The HD Channels were great up until about a few weeks ago. Now sometimes...
If your menus on the TV and other inputs look good then it is probably a resolution setting on your Directv box that needs to be changed. To get HD it needs to be set at 720p or 1080i. Please take a moment to rate my answer. Thanks....
Dec 02, 2009 | Televison & Video
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Vertical white lines on screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 10, 2017 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Samsung LN-T4661F 46 in. LCD HDTV Logo
Henry  Thomas
Henry Thomas
