Ok..I got this unit from my job when it stopped pumping water. I took it apart and found that the thermastat type piece was not opening up.. I removed it all together...it then worked for about 3 months...but what I think happened is the water backed up into the vacuum pump/motor
it is a two piece unit
Kas27h-002
and
370c-11450
i noticed water residue, and parts falling out
I know the parts are made by Koge...how can I find these parts
SOURCE: Keurig B100 not pumping a cup of water through
in the water tank you have 2 sillicon tube one of them is stretch at maximum and usaly strech in 2. cut the part split and connect it again. the probleme is because the silicon left is propryety when is strech in very hot water. the best way to slove this problem is to find about 1 in of silicon tube of 1/4 or 3/16 iner and put the new parts of tube directly on the bafle and put the original tube in the new on. it just make a link betwen the bafle and the original tube. put teflon tape on the fitting of the bafle to avoid of the new tube spout out from the fitting.//// but take care and other touble can cause this the pump can be jam because the one way valve on the side of the brewer jam open because is to teith in in is body. check all is thing .if you need somthing eles y will comme back on the site soon :0)
SOURCE: Keurig not pumping water at all
hi judy im pierre in montreal canada. judy do you decaicify once in a while caicium a killer that stuff is like ciment it clues the inside of the machine try to decalcify you said the pump is fryed put the stuff in leave it there for a few hour put it on try it use a turkey blaster to prime the pump hopefully it will start if it does work dont forget to rinse it very good very corosif stuff take care cheers
SOURCE: B100 only dispensing 1tablespoon of water and drawer does not open
descaling with vinegar forget that you said after you decaled it it worst vinegar remove calcium in little chunks ckunks bloc everything use a special descaler it melt calcium just to prove you that im right you said you saw lime deposit if you use the descaler when the water come out no residue just water color change 1 part solution 1 part water put it in container start machine for few second stop leave it for 15 minute repeat untill empty that a hell of cleanup after dont forget to rinse that solution is very corosif cheers
SOURCE: B100 Keurig
The pump is on the right side, has two wires coming out of it, and is connected to the check valve with a silicone hose. When you run a cycle, to brew a cup of coffee, that pump should be pumping air out, which pushes the hot water out of the tank.
So to test it, disconnect the hose and run a cycle to listen and feel for air coming from the pump. If it is not working (frozen due to the water permitted to enter from the failed check valve), you must remove it to dismantle the top part of the pump.
Getting the pump out is a little tricky... as you will see. There is only one philips head ***** holding it in, however, it is not easy to get to. I used a 90 degree angled *****driver, which worked well, after trying many other options.
Once you get it out, remove the three philips head *****s on the top of the pump right near where the hose was connected. Then separate the two sections of the pump. Inside there will be a fitting in the center that spins to actuate the pump. This fitting must be freely moving. If it is not, use WD-40 or a similar product to free the motor.
Clean up all the WD-40 from inside the chamber (so your coffee does not taste like oil) and reassemble. Then test it by running a cycle. The pump should now be working, if not repeat the process until the pump operates.
Since my last post, I have fixed another B100 that had the same issue. Keurig will not sell you a replacement pump or check valve, so you must repair that pump.
Good Luck, I hope this works for you. Erik
SOURCE: My B100 Keurig stopped pumping water
you will have to take the unit apart and on the inside of the water tank there is 2 silicone hoses. one of those fell off. you will have to put it back on. mine did the same thing.. hope this helps.
