Question about Dayton Heating & Cooling
I Have a outside A/C unit I have replaced the fan and I need to know which Capacitor leads go to the Fan, the compressor and the contactor. the capacitor is a 35/5 with one lead with 4 male blade connectors-one with two and one with only one lead. There are also two brown(one with a stripe)wires from the new motor instead of the one on the original motor.
  • 254 Answers
The 2 brown wires go to the capacitor, the solid on the positive or colored dot side, the striped one goes on the other side.
Posted on Jun 22, 2008
Our hear pump digital display is working but the top fan doesn't seem to be working.we have been away from the UK for and the unit has not been used for a while so cld that be the reason?
If you are talking about the top fan of your outside condensing unit, it could be several things. The fan motor could have failed, the run capacitor could have failed, or the motor is not getting power. Most units have a contactor that turns on the fan and compressor at the same time. If you only have one contactor, the fan motor or capacitor has failed. If you are good with a meter, check to see if you have voltage on the fan leads AFTER the contactor. If you do, I would recommend replacing the fan motor and capacitor
Aug 06, 2016 | Miscellaneous
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
Outside compressor and fan stay on
Hello, the relay/ contactor coils will be located in tje control panel of the outside unit. You can follow the the wires from the disconect box into the unit, it will lead directly into the relay/ contactor. When both the fan and compressor run nonstop even when thermostat is satisfied the the contactor is welded and must be replaced.
Jul 24, 2012 | Heating & Cooling
The compressor is not coming on
Is the fan in the outdoor unit coming on? If it is, that narrows the problem to just the compressor or capacitor. If neither is running, check the disconnect or circuit breaker or fuses that are located close to the outside unit. If the unit has power, remove the cover where the power goes into the outside unit, set the thermostat to make the unit come on and see if the contactor is pulled in. If it is, use a meter to check for power on the load side of the contactor. If the fan is running, check the capacitor for the compressor. Most units use one that works both the fan and the compressor. If the capacitor looks swollen then it is bad, otherwise use a multimeter with the capacitor check function to test it. If the capacitor is good, check the compressor motor windings with the multimeter on the resistance function. Let me know what you find and I can give you more advice if this doesn't get you going.
Sep 09, 2010 | Carrier 38CKC036 Air Conditioner
My downstairs Ruud AC will not blow any cold air. The fan in the outside unit does run.
Is the compressor running in the outside unit? If it is then check the capacitor for the fan and replace if necessary. If it's good then check the fan motor. If the compressor is not running also, check the circuit breakers or fuses and the contactor in the outside unit. Let me know what you find or if this helps, please rate it.
Aug 04, 2010 | Ruud UBHC Air Conditioner
Not colling, everything seems to be working inside the furnace, outside the unit does not make any sounds nor the outside fan is working.
you need to check for 240volts a.c. at the unit,then if you have it there then check for the low voltage 24 v.a.c. that controls the outside contactor that sends power to the compressor,if you have power to these components then replace the dual-section capacitor near the contactor one side is f for fan/the other side is h for hermetics(the compressor) /the c is common for both sides of the capacitor
Aug 01, 2010 | Goodman CKL49AR49 Air Conditioner
My compressor doesn't turn on. My thermostat
you probably need a start/run capacitor. on the out side condenser unit. about $100.00 to have it fixed,
Jul 03, 2010 | Heating & Cooling
Outside fan motor will not start. will this keep compressor from operating?
Is the compressor running? First check your contactor and see if it is pulled in energizing the fan and compressor. If it is then check the voltage at the load side of the contactor. If you don't have voltage at the contactor then check you breakers or fuses. If the contactor is pulled in and you have voltage then check the capacitor for the fan and compressor and replace if it is bad. If your compressor is running and the fan isn't it will cause you compressor to shut down because of high pressure. If the compressor is running and the fan isn't then again check the capacitor and replace it if it's bad.
May 22, 2010 | Goodman CKL24AR24 Air Conditioner
Ok you have to trace the wires on down to what terminals they go to on the fan and especially the compressor. Usually you cant go by colors but always by the names on terminals and the like.
The capacitor has labels like (C or Com) (Fan or F) and (Comp or Herm). The compressor has terminals like (Com or C) (S or start) and (R or Run)
Write all the colors down on the compressor and the terminals that correspond to the colors.
Then do the same for what you can trace to the fan motor (usually there are only 1 or 2 going to the fan motor) If it just goes into the fan motor write down all the colors that go from the capacitor to the fan motor. The other wires from your description haven't been chewed or removed correct? If this answer is other than correct we have another step to perform.
Mar 02, 2009 | Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
