Question about OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 Turbo -- Unclear characters in output
I have a 320 Turbo. Up until last week all was fine. When printing mailing labels there is a white line going horizontally through each line of type. This making reading the address, etc. difficult. For example you cannot distinguish between a 6 and 8. I have tried different positions on the label and different print heads. I had a spare 320 turbo and tried it, same problem. We have switched ribbons. Help! Postal service is not happy with the quality of the labels and they have to go out every Thursday.
How do I change ink and what is ink part #
Posted on Aug 26, 2008
  • 148 Answers
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Posted on Jun 21, 2008
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
We have a microline 320 turbo. we installed a new dell computer and now cant get the printer to print corectly on contineas feed labels. The print head starts on the right side and prints off the sheet...
Try downloading and installing an updated driver for your printer.
Here is the driver download page for your printer: MICROLINE 320 TURBO < Drivers & software
Select your operative system, download the file, then run the installer.
Mar 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Printer eventually outputs random characters/hash
actually this sounds like a controller board issue
Nov 05, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer is not advancing the paper
Check your software settings; it sounds like the Oki is getting additional (surplus) line feeds.
Aug 19, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo printer
Did you check your print queue? May be there is an error in there waiting for you to instruct it.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Jan 24, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
271 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
