Question about Frigidaire FGB24S5A Gas Single Oven
WILL NOT CONTROL TEMPERATURE
WE HAVE A PROBLEM WITH THE OVEN NOT RE-LIGHTING CORRECTLY AFTER IT TURNS OFF. WHEN I RAISE THE TEMP. CONTROL YOU CAN HEAR THE RELAY CLICK AND THE OVEN COMES ON AND WHEN THE TEMP IS LOWERED IT GOES OFF, AS IT SHOULD WITH NO PROBLEM LIGHTING OR TURNING OFF.THE.OVEN HAS HAD TWO CONTROLS AND THE IGNITOR REPLACED.I SUSPECT THE TEMP. PROBE BUT NOT SURE OF HOW TO GET TO IT. THIS BELONGS TO OUR PARSONAGE AND A SERVICE MAN IS HARD TO GET HERE. THIS IS A FRIGIDAIRE FGF326ASA MODEL
  • dmcfar1 Jun 22, 2008
    fixed problem.
  • 75 Answers
There is some adjustment in the switch to control it but according to ur problem the switch is weak though if u adjust the switch it will work properly only for few days or few months instead u can change a new switch to fix the problem permanently
Posted on Jul 29, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Dfg100 oven will light , get to temp, shuts off but wont light by itself again
to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
Apr 16, 2014 | Blodgett DFG-100 Gas Single Oven
My oven won't reach temperature all the time. it
It is adjustable. Pull off the temperature knob behind it you will find the adjustment to raise or lower the temp. You will need an oven thermometer to test after you adjust.
Sep 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
F5 - Mag Temp
Hi. this is a control fault. the board has lost the ability to communicate its commands to the temp relay. the sensor is also not working. Due to this malfunction, the control board cant regulate the temperature correctly and you will have to replace the board and temp sensor and relay in order to restore this oven to optimal performance.
Please rate and god bless:)
Apr 03, 2009 | TurboChef TORNADO Electric Oven
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
93 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
