Question about IBM ThinkPad T22 2647 Notebook
Crc1 error ibm laptop on booting it, it brings this error bad crc1 error
  • 67 Answers
That means that the data is corrupted somehow. It could be a damaged or bady written CD/DVD, or it could be data corruption on your hard drive, depending where the program is.
If it's on the hard drive, reinstall it. If it's the CD/DVD, you will need to get a new one, most likely.
Posted on Jun 21, 2008
Does any know how to fix a CRC1 error on an IBM laptop? pls help.
if you get this for a CD/DVD disc, your disc is bad...if you get this error on your hard drive, it means your drive is failing.
try to backup your data if possible and you will need to replace and reinstall all software. if the data is critical I recommend going with Drive Savers or another reputable recovery service.
Feb 15, 2010 | IBM ThinkPad T20 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
MY laptop beep twice and flag error code Bad CRC1, stop POST task
sounds as if one of your memory modules is defect.
CRC stands for Cyclic Redundancy Check and is a form of checking the memory.
If you have two modules inside, take on out and see what happens.
Best regards
Manfred
Dec 07, 2009 | IBM ThinkPad T20 2647 Notebook
ERROR 0175 BAD CRC1 COMMAND STOP POST TASK
the crc is the cyclic redundance check your bios is corrupt. you will need to flash the bios to bring it back the internal bios bottery will need to be removed for 1 min then replace. it should bring it back if not you bios chip has burnt out. i have never replaced a bios chip but you will have to find one to replace it
Jun 24, 2009 | IBM ThinkPad T60 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM'smag-glass_10x10.gif explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
Mar 25, 2009 | IBM ThinkPad T22 Laptop
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
Did't boot
You can try replacing theCMOS battery. This may work. Afterward set the bios to default. Please let me know how you make otu.
Jan 16, 2008 | IBM ThinkPad T20 2647 Notebook
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad T22 2647 Notebook Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
