Back to:
Tags:
Printers
Generic problem for all Printers
Lost connection between printer and (by 3 users)
posted by tpw02190 on Jun 21, 2008
lost connection between printer and computer
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by thebaby, posted on Sep 10, 2008
printer is on but when you want to print something and click print, nothing happens. Always worked befor but not working anymore
Comment by Guest, posted on Aug 04, 2008
printer will not print/ connection between printer and computer is lost.
Solution #1
posted on Jun 21, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
check cables. turn both cpu and printer off , then re-power on.
check control panel to see if printer is there.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on lost connection between printer and:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
installed printer but it is stuck on german language mode...
Printers
I have a lexmark x2690 and I can't figure out how to scan...
HP Color LaserJet 2600n Printer
When I print using my HP 2900n, the white paper is gray...
Lexmark X2470 All-In-One InkJet Printer
lexmark x2470
Printers
printer won't print. message says "close inner...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
