Question about Singer Quantum XL-1000 Computerized Sewing Machine
Yellow light on stitch indicator
I finished sewing a backstitch and then used the cut off button. Now I have a yellow indicator instead of green or red. The touch screen is unresponsive.
    Problem Solver:
  • 20 Answers
Try turning it off and on, again
Posted on Jun 21, 2008
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
Why is the fabric feeder pushing the fabric toward me instead of awayfrom me?
It is sewing in reverse. Shut down, restart the machine. If this doesn't help, press the backstitch button, and see if it stuck. Try changing the stitch length dial.
If this is an electronic machine, it may need to be serviced. This happened to a embroidery machine I had, when I tried to sew straight stitching. It needed to be service as it was an electronic issue.
Oct 27, 2014 | Sewing Machines
How do I back stitch
You push on the backstitch button. It's the button that looks like an upside down U. If all it does is take a few tiny stitches back then stops...you need to look at the screen...to the upper right you will see the upside down U and a scissors. make sure both of these are not selected. If one or both have a dark background...touch them and the background turns white/clear. Once they are unselected...you can backstitch at the same speed as going forward.
Jun 19, 2014 | Brother SE-270D Computerized Sewing...
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
Need to know how to do button holes
for an older sewing machine, one knob usually sets the button cams, or the step by step adjustments. for newer models, there is likely a button hole setting, the icon is probably a button hole (a tall narrow rectangle with thick lines). if none of this works, here are the manual steps for a proper button hole
1) Align needle all the way to the left. Set stitch length to smallest possible. Set stitch width to medium (2 or 3, machines are all different).
2) Stitch down in a line half again as long as the length of the buttonhole (always allow a little extra; it's okay!). Remember not to feed the fabric yourself; let the feed dogs do the work. The stitches will be very close together. This is the left side of the buttonhole.= '
3) Align needle to center. Stitch length remains as small as it gets. Set stitch width as wide as it can go.
4) Backstitch a small bit. Probably no more than 8 or so stitches; you may want to use the handwheel. This is the bottom of the buttonhole: '_
5) After reducing the stitch width to "middle" (same as step 1), you have two choices here: You can either backstitch up the entire right length of the buttonhole (pretty tricky, but a tad faster), or you can crank the needle gently down into the bobbin, lift the foot, rotate the garment 180 degrees, re-align the button hole so the lines will be parallel, and drop the foot again.
6) If you pivoted your garment, the settings for the third stitch are identical to the first stitch. If you did not, align the needle to the right before you backstitch. Either way, this is the right side: '_'
7) Return the needle to center, widen the stitch completely again, and either stitch or backstitch the final side 8 or so stitches.
8) use a seam ripper to rip the cloth in the middle... make sure you do not cut any of the stitching!
Sorry this is so long, I remember making these and wanted to get it down right.
Oct 30, 2010 | Janome MyExcel 3123
Singer Quantum XL-1000 Computerized Sewing Machine Logo
73 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
