Question about Viking VWH3048 Kitchen Hood
VWH 3648 Hood
All lights and blower are not working. How do I get at it to check wiring
    Problem Solver:
  • 50 Answers
Most of them you have to take the filter off. under the filter, there are some screws. take them out and then it should drop the motor and you will see the electrical.
good luck
Posted on Jun 23, 2008
Just got 84 lasharo rv ac blower dont work cant find fuze
If a GM chassis and problem is dash air, remove the power wire from blower (under hood) & apply 12 volts directly in order to confirm blower even works. Next, pull blower relay harness & check for arcing/burnt wires & contacts (usually the culprit this year GM). If good, trace wire to relay and check for 12 volts at relay (be sure to use a test light) and do this across the ground and power wires to relay and, relay to blower. Bad grounds and burnt contacts on relays are more of a problem than fuses during these years.
Oct 26, 2013 | Cars & Trucks
Blower motor not working. fuses appear to be ok. was working fine yesterday. any ideas?
Test the blower motor, turn on the switch and then with a test light conect it something that is grounded. Check for power at the harness, then connect the test light to the power side of the battery and test for grown at the harness if you have power and and ground replace the blower.
Feb 11, 2011 | 1995 Ford Mustang
Blower not working on a 1994 Cadillac
Go under the hood and test the positive wire that goes into the blower motor, it is a single wire with a sort of insuklated plug connector that locks onto a spade contact, check with a 12v test light if voltage replace the blower motor..very common, should be approx. 6 small 5/16 or 1/4 " bolts holding it in around its flange up against the fire wall on the passenger side top.
Jun 14, 2010 | 1994 Cadillac DeVille
Blower motor not working at all. 2003 ram van. checked, fuse, resistor, switch, relay.no power at the motor
the resitor operates ground, if theres no power then its a bad fuse under the hood in the power fusebox, or #10 fuse inside the leftside of dash, power for the blower comes from the ignition switch,double check all fuses,if you had no ground to blower then i would say the resistor,make sure you have a good ground on the test light, then check for power with key on again, heres a wiring diagram to help you, good luck.fd18d13.gif
Mar 23, 2010 | 2003 Dodge Ram Maxi
2003 Suburban heater fan will not working.
three things left to check,
using test light see if you have power at motor with key and switch on,if you do replace motor,if not locate blower motor resistor it will be close to motor,check for power going in,last is the heater control assembly
Dec 10, 2009 | 2003 Chevrolet Suburban 1500
Front a/c blower motor not working,rear blower motor works fine on 2000 astro van, how do I fix it?
check the resistors located under the hood, passenger side in the air box. two screws hold it in place as well as a wire harness to un-plug. common problem on gm and chrysler.
If thats not broke and rusted, then check the motor, fuse, and the relay.
Sep 11, 2009 | 2000 Chevrolet Astro
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
1993 Varvan, Not Turn Signals, No Heater Blower, And AIr Bag Light Now On
boy, that sound like a major circuit to cause all that. either a main fuse under the hood or a main circuit wiring harness connector. there are no unfused circuits that could indicate a short unless there has been past fuse blowing problems
Sep 28, 2008 | 1993 Dodge Caravan
Viking VWH3048 Kitchen Hood Logo
236 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
