Question about Pioneer Car Audio & Video
How do I remove a KEH 2730R Car stereo from my car
5 Suggested Answers
dinomb
  • 16 Answers
SOURCE: setting clock
Setting the time
This is used to set the time on the unit’s clock
display.
1 Press AUDIO to select the time.
Press AUDIO until the time appears in the display.
2 Select the portion of the time display you
wish to set with
2/3.
Pressing 2/3 will select a portion of the clock
display:
HOURMINUTE
As you select portions of the clock display the
portion selected will blink.
3 Select the correct time with 5/.
Pressing 5 will increase the selected hour or
minute. Pressing ∞ will decrease the selected
hour or minute.
Posted on Mar 30, 2008
Mike258
  • 1498 Answers
SOURCE: I have a very old
Hello Maddeshi
There are two power inputs. Normally a red and a yellow.
The red is hooked to the IGN power. When you turn off the vehicle, radio turns off too.
The yellow should be connected to the battery (+12VDC) so it always has power. This is how it keeps the memory, the time.
It sounds like the are both hooked to IGN. Each time the vehicle is turned off, the memories are lost.
Your post says, "When I turn off the radio". If this happens with the vehicle still running, we have to dig a little deeper.
Hope this helps you,
Mike
Posted on Jul 28, 2008
SOURCE: removal of 57 plate x type jaguar car stereo
unclip plastic surround from gear stick, then remove ash tray - i know i didnt think it sounded right either...carry on...remove plastic cover now thats hiding 2 torx screws, remove them.
at the top of the unit near the hazards, that little section pops off to reveal 2 more torx 60? screws, remove them, and it will just pop out.  the unit looks like it could just slot the stereo part out but you cant.
Posted on Nov 30, 2008
  • 14 Answers
SOURCE: pioneer car stereo mod KEH-2250QR
if you have a wire harness from the original install then they are 99% of the time just color coded or you can order a replacement manual from there website http://parts.pioneerelectronics.com/model.asp?modelNum=KEH2200QR
Posted on Dec 09, 2008
  • 69 Answers
SOURCE: Chevrolet Cavalier Car Stereo Removal Instruction
take off defroster grill
take out the two screws under the defroster grill
remove dash side end caps
remove one scre from each side
In the glovebox area remove the two golden colored bolts they are up through the hole in the top of the glovebox
then there are three more screws right were the top of the glovebox door would be if it were closed
lift up on the dash and pop out the locater pins above the gauge cluster
then remove the dash cover
then remove the dash face by removing the screw on each side of the gauges and the last one to the right of the center vent (these go down from the top)
then unclip from around the radio and unplug the wires and remove the face
then unbolt the radio and remove
assembly is reverse
Posted on Mar 28, 2009
HOW DO I FIND THE SERIAL NUMBER AND DECODE A PIONEER CAR RADIO MODEL DEH-M6106ZH
the serial number, reads in a sticker on your hardware, it may be on the top, bottom, sides or back.
For example, this is not your device, but just a example, computer cd drive
Oct 05, 2008 | Audio Players & Recorders
I have a pioneer keh-p5400
You are not going to be able to find a new radio that will run a changer.
Nov 10, 2011 | Pioneer KEH-P5400 CD Changer
I am having KEH-P8900R/X1B/EW PIONEER, by default it is playing the radio station FM- AF, I am trying to change it AM, but I did not get sucess. Can you please advice, how to change it. Thanks &...
There should be a "band" button on the stereo. you may have to press it several times before you get to AM mode, depending on how many FM stations it will store in it's memory.
Mar 25, 2011 | Pioneer KEH-P8900R Cassette Player
I Loss The Face Plate
Remove the stereo and check the model and serial number in the back
and check http://parts.pioneerelectronics.com/
and they might let you know if they have it available and the cost
have a nice day
Dec 06, 2010 | Pioneer KEH-P1010 Cassette Player
I have a car stereo model pioneer KEH-1550 (cassete), and I don't know how to install. Can anybody tell me how to install it? Thank you.
Go to a car stereo place and buy an "install kit" That will solve all your problems. Wiring, and how to fit it in
Apr 12, 2010 | Pioneer KEH-1700
Trying to hook up a pioneer car stereo model # KEH M8550
Depends on the type of car you have. Do you have a harness or are you going to splice all the wires? Does your car have a premium sound system? Are you going to run an amplifier now or later on in the future??
May 03, 2009 | Pioneer Car Audio & Video
Pioneer car stereo mod KEH-2250QR
Sep 17, 2008 | Pioneer Car Audio & Video
Hi, I need a wiring diagram for a Pioneer KEH-P3630R Radio/Cassette system
s.gif Faisceau avec connecteurs ISO pour autoradio PIONEER 12 broches
NEUF SOUS BLISTER
16 broches sur ISO - Dimensions de la prise environ 43 x 8 mm
Détail des câbles des haut-parleurs :
Blanc : HP avant gauche +
Blanc/noir : HP avant gauche –
Gris : HP avant droit +
Gris/noir : HP avant droit –
Vert : HP arrière gauche +
Vert/noir : HP arrière gauche –
Violet : HP arrière droit +
Violet/noir : HP arrière droit -
Détail des câbles d'alimentation :
Jaune : Permanent + 12 V batterie
Rouge : Alimentation + 12 V après contact
Noir : Masse
Bleu : Antenne motorisée
cote_g_olitec_j.gif Liste des autoradios compatibles :
cote_g_olitec_j.gif Série KEH cote_d_olitec_j.gifKEH-1100SDK
KEH-1150SDK
KEH-1200SDK
KEH-1300K
KEH-1300R
KEH-1300SDK
KEH-1311
KEH-1400R
KEH-1400SDK
KEH-1450
KEH-1450R
KEH-1500
KEH-1500R
KEH-1530
KEH-1530R
KEH-1540
KEH-1700
KEH-1700R
KEH-1730
KEH-1730R
KEH-1800R
KEH-1830R
KEH-1900R
KEH-1930R
KEH-2100R
KEH-2300R
KEH-2400R
KEH-2500
KEH-2500R
KEH-2520R
KEH-2530R
KEH-2700R
KEH-2710R
KEH-2720R
KEH-2730R
KEH-3400
KEH-3520R
KEH-3700R
KEH-3710R
KEH-3720R
KEH-3730R
KEH-4400R
KEH-4500R
KEH-4530R
KEH-4700R
KEH-4730R
KEH-5700R
KEH-5730R
cote_g_olitec_j.gif Série KEH-P
cote_d_olitec_j.gifKEH-P26R
KEH-P27R
KEH-P28R
KEH-P2800 R
KEH-P2830R
KEH-P3300 R
KEH-P3400 R
KEH-P3600 R
KEH-P3630R
KEH-P3700R
KEH-P3730R
KEH-P4300R
KEH-P4400R
KEH-P4500R
KEH-P 4510
KEH-P4530R
KEH-P4600R
KEH-P4610R
KEH-P4630
KEH-P4630R
KEH-P4700R
KEH-P4730R
KEH-P5700R
KEH-P5730R
Jul 14, 2008 | Audio Players & Recorders
PIONEER KEH-P1010
depends on the kind of car, if there is a "CAN" around it then there is a metal cahe that you need to slide 2-4 removal tools in the sides to remove it, you can use any think metal tabs abought 3-4 in long as removal tools,
if its an ISO DIN mount there are screws holding it in from the sides.
if this doesnt help much can you tell me the make and model of the car?
Jan 03, 2008 | Pioneer KEH-1800 Cassette Player
Car Audio & Video Logo
51 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
