Question about Hoover WindTunnel TSeries Bagless Upright Vacuum Cleaner UH70107
Wind tunnel t series vacuum won't turn on - Hoover WindTunnel TSeries Bagless Upright Vacuum Cleaner UH70107
    New Friend:
I had the same problem and used a tool to clean out the suction tube on my Windtunnel Series T. It was full of junk packed in tight. After cleaning it out there's no more turning off or overheating. It actually works better than when I first got it (used from a friend).
wind tunnel t series vacuum won't turn on - wind-tunnel-t-series-vacuum-turn-z0fb4p0zfxquqkotqdqr0yh5-2-0.jpg
Posted on Jul 11, 2015
SOURCE:
SOURCE: where is reset button on Hoover Wind Tunnel
Hello my good friend, this cleaner doesn't have a reset button or anything, it resets by itself after cooling down, it takes about 30 minutes to cools down.
Posted on Jul 26, 2010
SOURCE: Hoover Wind Tunnel ON/Off Switch
This happens all the time on our vacuum. Just remove the handle and switch the button manually inside. You will have to do this from time to time as the power switch on the outside will constantly stop working. This, along with the belt replacements are the common complaints on this machine.
Posted on Jul 28, 2008
  • 30 Answers
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Motor front bearing retainer probably melted from grit. Replace motor. The motor's rotor is dragging on the stator.
Posted on Mar 27, 2009
SOURCE: Hoover Wind tunnel V2
Mine was under warranty and they replaced the whole assembly for free. Apparently a quality and/or design problem.
Posted on Jun 17, 2008
Buffalo12980
  • 625 Answers
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Posted on Sep 22, 2007
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Why won't my hover wind tunnel vacuum turn on
First of all you have checked to make sure you are plugging into a outlet that has power correct ? If you have power at the outlet then when you activate the switch does it make any noise at all ? If not you may have a defective switch. If it's making a noise you may have a broken belt or something jammed in the brush.
Sep 03, 2014 | Hoover U8126-900 Wind Tunnel Dual V...
Hoover Wind Tunnel T Series Bagless Rewind -
To answer this question requires knowing specific model information. T-Style, for example, could use one of 4 different belts, depending on the features of that particular model. Just like your Firebird T-type may have different upholstery, audio system, or engine. More information needed.
Jan 28, 2014 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Where is reset button on Hoover Wind Tunnel vacuum?
Nov 07, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Wind Tunnel does not turn on
that is a pretty good lifespan for a hoover, but its probably the power switch that's bad. Hoover uses a very poor quality switch. It shouldn't cost to much to have it replaced
Jul 05, 2009 | Kenmore 33721 Upright Vacuum
Wind Tunnel Model: u6630900
Need a manual for Hoover Vacuum Cleaner, Wind Tunnel Model:u6630900
May 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover WindTunnel TSeries Bagless Upright Vacuum Cleaner UH70107 Logo
15,625 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
